Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: problems with my emaxx
Old 12-10-2006, 12:54 PM   #1
Exclamation problems with my emaxx
i everybody
i have a traxxas emaxx all stock...ALL
i have it for a year and i bought it new at tower hobbies
first i run it with 7.2v batteries then i put some 8.4v batteries
so the problem is
my emaxx theres days that he doesnt want to move (anything ...it even doest turn the wheels) so i put new batteires to the control and to the car
......and nothing:-(
but lately my emaxx is running but when my emaxx is like 3 feets away from me he doesnt move
i think is the tq3 but i put new batteries and nothing:-(
what can be my problem??:-(
thanks a lot
andres-tavares is offline   Reply With Quote
Old 12-10-2006, 02:18 PM   #2
Loose connections somewhere between your batteries and motors?
Loose antenna connection?
Check and re-check all your connections and go from there.
Cheftyler is offline   Reply With Quote
Old 12-10-2006, 05:34 PM   #3
no the battries conecttions are good i have never touch it
the antena is good
i cant find anything in bad shape
Old 12-10-2006, 06:34 PM   #4
It could be the radio crystals
Acs_guitars is offline   Reply With Quote
Old 12-10-2006, 06:45 PM   #5
may be
i would try when my new tq3 comes for my tlt
i can interchange the control...the reciever or even the crystal
i would try
thanks
Old 12-10-2006, 07:53 PM   #6
Before switching the entire radio, switch the crystals out and see if it make a difference.
Old 12-11-2006, 02:28 PM   #7
yeah i will do that
thanks
just have to wait ..................dec 18
Old 12-14-2006, 04:56 PM   #8
well from what someone said about the battery connectors could be true if the truck is a year old those tamiya connectors could just be plain wore out. I would put some better connectors on the batterys and esc like powerpoles or deans. It would explain why it moves a couple feet and stops because the vibration losins the wires. Also check the antenna on the radio.
1.1 sport trac is offline   Reply With Quote
Old 12-14-2006, 07:52 PM   #9
also make sure you have the wires connected into the receiver correctly ive had a similar promblem before
Got Rocks? is offline   Reply With Quote
Old 12-14-2006, 08:16 PM   #10
sfrankland's Avatar
I had the same issues with my electric but I redid the battery connector and I was back in business.
sfrankland is offline   Reply With Quote
Old 12-16-2006, 03:47 PM   #11
thanks i will check all that
Old 12-28-2006, 07:36 AM   #12
if you change plugs go deans or powerpole. Then you will never go back to the stock tamiya plug
Old 12-28-2006, 04:33 PM   #13
wl6
Switched mine from tamiya to deans, no more problems!
wl6 is offline   Reply With Quote
Old 12-28-2006, 06:01 PM   #14
where i have to put the deans connector
on the battereis...check
on the esc wires...check
in the motor wires??
i dont know
Old 12-28-2006, 06:02 PM   #15
i put a different tq3 and a different crystal and my emaxx...still having exactly the same problems
Old 12-28-2006, 07:15 PM   #16
Colt Python/SR9c
TwistedCreations's Avatar
sounds like the actual reciever itsself is screwed probably
TwistedCreations is offline   Reply With Quote
