Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: revo shaft question!!! help pls.....
Old 12-15-2006, 05:29 AM   #1
Default revo shaft question!!! help pls.....
helo guys, i have a question.... would the revo shaft work if i have 19" wheel base and 5" ground clearance? need help fast..... thanks
jr17ca is offline   Reply With Quote
Old 12-15-2006, 10:58 AM   #2
I dont think it would be long enough for a 19 inch wheel base and 5 inch ground clearance
Brandon M is offline   Reply With Quote
Old 12-15-2006, 05:19 PM   #3
chevellian's Avatar
you wiil have to lengthen them.
chevellian is offline   Reply With Quote
Old 12-15-2006, 06:31 PM   #4
Colt Python/SR9c
TwistedCreations's Avatar
Originally Posted by skogsvild
What is the wheelbase of this thing
You gotta be kidding me?
JR- You will have to lengthen them. I had some on a 17" WB rig and that was pushing the limit
TwistedCreations is offline   Reply With Quote
Old 12-15-2006, 07:44 PM   #5
oh ok. well i found a pbc plastic tubing. its hard as the half shaft. i think im just going to use them, drill a couple of holes on both ends. what do you guys think? ill post some pics after i finish it.
Old 12-15-2006, 07:48 PM   #6
wl6
wb is at 18" on my build, not much holding on, but I shall see how the shafts hold up when done.
wl6 is offline   Reply With Quote
Old 12-23-2006, 06:41 AM   #7
wl6
I started to test fit everything and decided to shorten the wb from 18" to 16". Turning the shafts by hand I was watching them move around way to much and when I was flexing the chassis the front shaft popped out. Plus the axles are more under the chassis a little better now.
