| | #1 |
| Newbie Join Date: Dec 2006 Location: casper
| i'm making a e-maxx into crawler to just mess around with. it's not going well for me.... i'm having troubles hunting down lower gears for it does anyone know a good web site.... also does anyone have some suggestions on how to keep this cheap since it is just being used for amusement and not compition. any help is appreciated. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
| Lock the tranny into low only You can use lower tooth count pinion (8tooth)for 32 pitch spur Plus theres always a gear reduction Check out rc4wd |
| | #3 |
| Rock Stacker Join Date: Oct 2006 Location: Mounds
| | #4 |
| Quarry Creeper Join Date: Feb 2006 Location: Shillington
| I have 2 55T lathe motors with 8T pinion gears and it works great. You need to lock it into 1st gear. (Tech) How to lock an Emaxx trans into 1st gear Good luck. |
| | #5 |
| Newbie Join Date: Oct 2006 Location: Chandler
| I have locked both front and rear diff , Moab XL tires , beadlockers , 55 t motor , single battery conversion , geared as low as possible , etc , etc , on my E Maxx , and may I ask why it is needed to lock the tranny in first gear only ? Last edited by $maxx; 01-02-2007 at 08:19 AM. |
| | #6 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| The easiest way to convert your emaxx IMO is to switch out the motors. You could try two 75t motors on 12 cells, or two of these cheap 5 pole motors on 12 cells 5 Pole Brushed Motors! either motor will get you going slow with lots of torque. No need to lock out your tranny. Getting rid of the two speed does help the drivetrain slop, but not much more advantage to it. |
| | #7 |
| Shut up Dave ![]() Join Date: Dec 2005 Location: Romeotucky
| something I noticed from the pic, it looks like you are running full foam in the tires, I could be wrong but if you are I would eliminate most of it to get more squat and more bite |
| | #8 |
| thanks for all the advice. i'm gonna try it out. i'll post some pics once i get it done. |
| | #9 |
| | #10 |
| Newbie Join Date: Jun 2005 Location: tenn
| i think your rig looks pretty good stock |
| | #11 |
| Newbie Join Date: Dec 2006 Location: Cotati
| u could try puting bb's in the tires |
| | #12 |
| thanks for all the advice guys. |
| Thread Tools | |
| Display Modes | |
