Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: E-Maxx 8x8 goes X2
Old 01-06-2007, 09:35 AM   #1
Default E-Maxx 8x8 goes X2
Hi!
A view month ago I started the next evolution step of my E-Maxx 8x8 and totally rebuilt it. Thatīs the result:
Click pic 4 gallery!
No, itīs not simply 2 E-Maxx bolted together. Yes, the agility is a lot better then the "standard" 8x8 layout. And I know I have to put a better looking body on it...
And thereīs also a video of it: E-Maxx 8x8 X2 (93MB MPEG2) (rightclick --> save as)
Next steps to do:
-Buy a new Proline Jeep CJ8
-Build a body for the tail
-Mount two dampers at the joint in the middle
-Build or buy an external BEC
Manuel
Uncle_Manuel is offline   Reply With Quote
Old 01-06-2007, 09:44 AM   #2
it's an e-maxx with a tagalong......
i would keep the hummer body, but make it flexable in the middle
rockman27 is offline   Reply With Quote
Old 01-06-2007, 10:08 AM   #3
Originally Posted by rockman27
with a tagalong
A what?
Hmmmm, the hummer body should be a nice try. But the big problem are the many holes in it...
Manuel
Old 01-06-2007, 02:11 PM   #4
an attatchment, like you see the tractor trailors with 2 trailers, the 2nd trailer is a tagalong.
if it had a flexable middle section, it would work....
Old 01-06-2007, 04:50 PM   #5
its not really a tagalong...because the 2nd emaxx has a motor too with steering also so its working as well
jrdk92 is offline   Reply With Quote
Old 01-06-2007, 07:54 PM   #6
if you did do a fifth wheel attachment you could set up ur controller for independent rear steer then on trial's you would be able 2 swing the rear out for hard turns. just giv'n my 2 cent's
BigRich is offline   Reply With Quote
