| | #1 |
| Newbie Join Date: Dec 2006 Location: canada
| Heres a couple of pics of some axles im making out of revo parts ![]() ![]() |
| Sponsored Links | |
| | #2 |
| Release your anger.. ![]() Join Date: Oct 2006 Location: North American Union
| neat, i've been thinking about making some axles outta of revo shafts and diffs too like this something a little different, revo hybrid strait axled crawler . Tell me How wide are the Axles?was it difficult to make the housings? |
| | #3 |
| There about 11 1/8 from flange to flange the way it looks , but assembled its about 13 1/2. Luckily a good buddy has a spool gun (not the best for small aluminum pieces but worked) to weld it all together. So far not too hard if your carefull with a tablesaw/chopsaw |
| | #4 |
| Rock Stacker Join Date: Jan 2005 Location: Windsor/Detroit/Edmonton CANADA
| stainless, what part of Canada you in...Ontario, BC. |
| | #5 |
| Newbie Join Date: Dec 2006 Location: Cotati
| is that where the links are going to connect on bottom of the houseings |
| | #6 |
| Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
| Those axles look good. Those lower mounts might get cought on a rock tho. |
| | #7 | |
Those tabs are for the lower links, a sacrafice i had to make to get the steering on the backside of the axle. I plan on using stainless for the lower links so should slide ok | |
| | #8 |
| Rock Crawler Join Date: Jun 2006 Location: Sinking Spring
| Looks good so far! |
| | #9 |
| I finally received most of the parts I ordered, and have the axles locked and assembled |
| | #10 |
| Newbie Join Date: Dec 2006 Location: minnesota
| that looks amazing, keep up the good work |
| | #11 |
| Rock Crawler ![]() Join Date: Sep 2006 Location: Lititz
| Killer axles Stainless Aluminum tube frame will be very light, although I don't think it will hold up well. I am by no means an expert, but I have bent steel tubing on rollovers. also tried some aluminum tube links, they didn't last a day. |
| | #12 |
| Newbie Join Date: Feb 2007 Location: philly
| lookin good so far |
| | #13 | |
Yeah what he said. It looks killer! Keep up the great work! | |
| | #14 |
| Pebble Pounder Join Date: Jan 2007 Location: So.Cal
| Very nice... surprised a spool gun is letting you do that small of work.. mine will just tare through aluminum that thin JOe |
| | #15 |
| Heres some progress pics,got the links done today |
| | #16 |
| Pebble Pounder Join Date: Mar 2006 Location: Crow Head
| Do you have any flex shots with your present shock setup. The axles cleaned up real nice. I just about finihsed my tube chassis but now thing I am going to rebuild it with 1/4" steel rod. But I may try one out of aluminum later down the road. Also just looking at your top links and it looks like they would work better if the where mounted on the inside of the bracket rather than the outside. |
| | #17 | |
| | #18 |
| How is the axle for side to side motion. By moving them to the inside of your mount you will have better triangulation. What did you use to build the axles. I was thinking about Revo diffs but never having seen one up close I stayed clear. But having seen yours it looks like a better way to go than the Maxx diff. |
| | #19 |
| RCC Addict ![]() Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| Hey Great Build SUPER Clean and SIMPLE Really like your axles , great light strong idea Nice light simple frame What Trans are you using? Any advantage to using Revo Diffs ? Why did you mount your Lower links UNDER the axle ? How do the links work out ? they look a little short how are you fabrication the tube and axles, mig welder or ?? Thank you and Great Build up Last edited by toy4crawlin; 02-19-2007 at 12:12 PM. |
| | #20 |
| sfranklandHow is the axle for side to side motion. By moving them to the inside of your mount you will have better triangulation. What did you use to build the axles. I was thinking about Revo diffs but never having seen one up close I stayed clear. But having seen yours it looks like a better way to go than the Maxx diff.I didn't notice any side to side movement,but i'll check. Also I'm using a team losi xxt tranny not too sure about advantages of revo diffs, but they seem tough as for the lower links,if I had cvd's I could tuck them up a bit more but the revo axles got in the way as for the links ,the wheel base is 16 inches and the links seem to work ok so far. and the welding is done with a spool gun, a mig welder basically but the spool of wire is on the gun you hold. |
| Thread Tools | |
| Display Modes | |
