Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: my first crawler build
Old 01-17-2007, 08:17 PM   #1
Default my first crawler build
Over the last 9 months or so I've been collecting the parts to build a crawler. I finally got it finished (for the most part) yesterday and got to play with it in the snow a little bit.
*specs*
emaxx tranny locked into 1st
spooled diffs
integy 55t motor
hitec 645 front steering servo
tower pro 955 rear steer servo
double j custom axles
double j verticle smile chassis
ordered a moped esc as well so i can run off of one battery.
I'm still working on the servo brackets, so they are just held on with tubing clamps for now. I need some stiffer springs but was surprised with what little torque twist I had, even with the shocks mounted to the links.
i've also moved the battery to the upper links.
*pics*
here is my modded tq3. the third steer wheel is self centering by using the steering wheel setup out of a broken Tq Tx.
bulzeye is offline   Reply With Quote
Old 01-17-2007, 08:39 PM   #2
Default sup!
LOOKs prety good so far. Why the two batery system? I realy like using the steering wheel out an old radio I thought a LONG time about that but could never find a good place to mount it , kudos to you!
alabamaman is offline   Reply With Quote
Old 01-17-2007, 09:34 PM   #3
i noticed with 1 battery i was having problems getting up obstacles. with both batteries i get a lot more wheel speed and torque
Old 01-18-2007, 05:05 PM   #4
Default ok
If you are using the traxxas evx esc have you tried to short out one side using a plug where you still get 14.4 volts and only have to carry the weight of one battery . I fergot whitch side it is but the skinny is on here serch for it, it might help alot!!!!!!!!!!
later
Old 01-18-2007, 09:03 PM   #5
Keep it real
Tanis's Avatar
You only get 14.4volts by running 12cells. 1.2v per cell x 12=14.4v
Tanis is offline   Reply With Quote
Old 01-20-2007, 06:21 AM   #6
great job,
Whats its waight?
hodgy_789 is offline   Reply With Quote
Old 01-20-2007, 09:06 AM   #7
Originally Posted by hodgy_789
great job,
Whats its waight?
i'm not sure. i don't have a scale at my house. i'll post up the weight sometime after this weekend. my brother has a scale at his house.
Old 01-23-2007, 02:23 AM   #8
great job,
Whats its waight?
with both batteries it weighs 12.5 lbs
Old 01-23-2007, 06:54 PM   #9
lookin good
derrick1032 is offline   Reply With Quote
Old 01-29-2007, 06:44 PM   #10
looks good
maxxcrawler309 is offline   Reply With Quote
Old 01-30-2007, 04:58 AM   #11
Looks awesome! Whats the wheel base?
Toph is offline   Reply With Quote
Old 01-30-2007, 11:50 AM   #12
wheel base is 17"
got my moped ESC
added some bb's to the tires
now i just need cheapbatterypacks.com to get some cells in stock so they can build my pack
Old 02-03-2007, 02:36 PM   #13
Pretty sweet
sportsman1213 is offline   Reply With Quote
Old 02-03-2007, 06:44 PM   #14
toy4crawlin's Avatar
Sweet job
What are " J custom axle " ? are they steel, alumin. plastic
Where did you get the beadlocks ?
What's next ?
toy4crawlin is offline   Reply With Quote
Old 02-07-2007, 12:59 AM   #15
the axles are made by the user Double J on here. they are steel.
the beadlocks are maximizers.
next will be to finish the servo mounts, have a little grinding to due to clear the steering links better, new V10 motor from Axiom, new battery pack from cheapbatterypacks.com
Old 02-16-2007, 04:59 PM   #16
NICE BUILD WHAT DID YOU USE FOR THE AXLE TUBES
REVOlution is offline   Reply With Quote
Old 02-16-2007, 05:02 PM   #17
look one post above yours
Old 02-16-2007, 05:07 PM   #18
Ha Ha The Only One I Didnt Read
Old 02-17-2007, 11:47 AM   #19
nice crawler!
jhcrawler93 is offline   Reply With Quote
Old 02-17-2007, 08:59 PM   #20
keep up the good work!
maxxmagic is offline   Reply With Quote
