| | #1 |
| Quarry Creeper Join Date: Nov 2005 Location: fairfax
| Geines look better but Gins are cooler. anyway i kind of got that name from the way it turned out looking. just figured i'ld share a few pics. layout out a plan and made some cuts: ![]() anybody else use the board trick for bending tube? pretty slick... burned up a base; ![]() topped it off and added a belly pan. total hieght just over 5"; ![]() since i had a maxx tranny laying around that's what i'm using. instead of locking it into 1st gear i decided to buy the gears to make it a sinlge speed tranny. like the one found in the original Sportmaxx trucks (F.O.C., 28/41 gear, 19t gear). gave me a 2.3 ratio. need a GD600 right? got to mount it right? here's what i came up with ![]() ![]() axles and a quick mock up; ![]() ![]() pheww..... |
| Sponsored Links | |
| | #2 |
| okay one more time.. here's a few of how it stands now. front shot; ![]() rear shot; ![]() sides; ![]() ![]() tranny and cockpit; ![]() ![]() cleaned up axles; ![]() think my electronics are coming from Holmes or the CrawlerStore. would really like to put a revolver in it but not sure i can afford that. i have a while before it's ready for a motor though so ya never know need a half inch added to the links on the front (shock slant backwards), spools for the diffs, and front dig setup, and a mounting plate for the electronics what do ya think body panels or not? |
| | #3 |
| that's not all the pics, you can see every pic i've taken at the this link http://jackyl.homestead.com/TUBER.html |
| | #4 |
| Newbie Join Date: Jul 2006 Location: Cape Coral
| Maybe just a panel to cover bottom of tranny. For the shock mounts, is that just some cut to shape metal and welded in place? Thats some crazy bends, but finished product looks great. |
| | #5 |
| Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
| That looks Awesome. I started to make a Jig when I built my last chassis, but gave up and built it all by eye. |
| | #6 | |
if you mean the very bottom of the tranny it will get the belly pan i just haven't mounted it up yet. i was also thinking maybe using some very thin guage steel (22 i think it is) and wrapping just the lower sides and front sections right in front to help protect the cockpit | |
| | #7 | |
THANX for looking guys | |
| | #8 |
| Rock Crawler ![]() Join Date: Sep 2006 Location: Lititz
| Looks great raptor If you want to run in comps you will need body panels. 2007 Usrcca Rules Comittee Updates I would build them anyway, I think tubers look better with some sort of body to them. |
| | #9 |
| no comps in my area unfortunately. however i have a whole plot of land (10acres) that is all ledge and rocks. since i'm probably not gonna keep it when it's all said and done i think i'll will make it comp legal. should have some more pics by the end of the day |
| | #10 |
| Pebble Pounder Join Date: Apr 2005 Location: World -> Europe -> Italy -> Umbria -> Perugia -> Assisi -> Petrignano di Assisi
| Very nice job man!!! Good tube work and nice idea for tranny case!!! |
| | #11 |
| Powered by Awesome ![]() Join Date: Sep 2004 Location: Castle Rock, Colorado
| awsome tube work!!! i love the design of the rear, and im stealin you idea on how to bend the tubing cleaner! |
| | #12 |
| Newbie Join Date: Apr 2006 Location: Calgary, Canada
| the tubework is different,I think ts growing on me |
| | #13 |
| Thanx for the compliments. i haven't got much done to it lately. did get the front servo mount made and the axles cleaned and painted. will get some pics up tonight. i would have the links all done but i thought i was gonna be 4 rod ends short, then found some in one of my bins. now i can finish them up this evening. need to pic up some thin sheet metal for the panels too. that will probably be this weekend. then after i cut them everything can be painted up. |
| | #14 |
| well here's the pics so far i keep telling you i'll post. funny how life will give you all this free time, then all of the sudden there aren't enough hours in the day. FRONT AXLE: ![]() ![]() REAR AXLE: ![]() TOP SHOT: ![]() working today but i think i'll be able to get the body panels cut tomoro. hopefully i'll be able to get the electronics within the next couple weeks |
| | #15 | |
| | #16 |
| | #17 |
| Rock Crawler Join Date: Jun 2006 Location: Sinking Spring
| Looks awesome! |
| | #18 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| I really like those panels! The wb looks to be a hair under 17 Toph. You might have some troubles with the ballends binding. Your lower link mounts are horizontal and it can screw up articulation at those angles. I would also recommend lowering your ride height, maybe setting the shocks up for some droop travel at the same time. |
| | #19 |
| yep wheel base is right around 16.5". you know, when i finally finished my aluminum links and had it set the way (i thought) i wanted it, i was noticing some of the binding your mentioning. my thought was maybe the rod ends were mounted too close together, didn't really think of the direction they're mounted in. have to check into that too. may have to move the link mounts. i haven't messed at all with the suspension yet. need to get the electronics in it so i know what kind of weight i'm dealing with |
| | #20 |
| got some more done: painted chassis and mounted some panels, went with paint cause i had it instead of buying more stickers: ![]() ![]() ![]() ![]() redid my link mounts like suggested, much better: ![]() ![]() ![]() flip top hood to cover the motor compartment (think i missed a spot when cleaning the chassis for paint: ![]() and a velcro radio plate for the RX and ESC:] ![]() batteries just showed up today, the rest of the electronics should be here by next week. almost done |
| Thread Tools | |
| Display Modes | |
