| | #1 |
| Quarry Creeper Join Date: Aug 2006 Location: NORTH TEXAS
| Well i am not done yet but wanted to show yall. let me know what ya think. this is the standard flex shot. ![]() Shot from the top shows the chassis lay out, the blue piece is the esc mount. ![]() close shot of the front axle......... yes thay are PVC! ![]() shot of the rear axle ![]() shot from the bottom ![]() just another shot of the front. ![]() i am getting the motor and some moabs along with a new servo. it has stampede wheels and tires on it right now so the ride hight will be a little more with the new tires. i used pvc "T's" cut and milled out for the steering knuckels. 4tec hub carriers on all 4 corners. jato drive shafts in the axles that are connected to spools. max drive shafts are used for the drive shafts. revo push rods are used for the lower links bent (actualy i had to bend them so it would make 12.5 w/b). jato camber links are used for the upper links. the rx will go in the rear link mount and a 2/3a 6 cell pack will be mounted on the servo in the front. i should be able to get it running this weekend i will get some action shots if the weather permits. the final ride hight will be about 1/2" or so lower. hope yall like it! Last edited by ON THE FARM; 06-13-2007 at 09:11 PM. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: May 2004 Location: delavan
| very nice i like it do you have a pic with the servo off the axel |
| | #3 |
| Pebble Pounder Join Date: Oct 2006 Location: australia
| looks great Good job |
| | #4 |
| Pebble Pounder Join Date: Apr 2006 Location: grand rapids
| Is the PVC attached to the maxx differential with ca or epoxy or is there something I'm missing? |
| | #5 |
| I wanna be Dave ![]() Join Date: Oct 2005 Location: Columbia TN
| I'm worried about the jato shafts that far down the line in the gear reduction. |
| | #6 |
| DumpsterRC: Yes the pvc is glued to the diff housing with an industrial grade CA. doing some testing the pvc broke before the joint! Kamikaze: I was thinking about that also but we will have to see what happens, there is enough room for max shafts but we will see. usa1man: Well i took it for a test run and rememberd that i forgot to one of the diffs was in backwards, so when i took it apart i took some more pics for yall. ![]() I used the ring gear sides of the diff housing for both sides. ![]() this shows the revo drive shafts in the pvc housing. ![]() a shot of the steering ![]() its all back together shot from the rear ![]() front shows the battery on the servo. ![]() another flex shot ![]() side shot ![]() i will need to get some softer springs to get the ride hight i am looking for, the t-maxx springs are a little too stiff. hope this helps. |
| | #7 |
| Rock Crawler ![]() Join Date: Feb 2006 Location: Cutting Comms
| Updates? |
| | #8 |
| Quarry Creeper Join Date: Jan 2005 Location: GUAM
| just found this thread any updates |
| | #9 |
| Quarry Creeper Join Date: Feb 2007 Location: East Aurora
| wow man the more isee this thing thte more i like the pvc idea but idk if i did it i would use smaller but thincker pvc, idk why but i think it would look better but still grea! |
| | #10 |
| this rig works great! i made a tuber for it and that started the ball rolling. i made a better improved version of the axles and they work even better. the only reason i used the 1" pvc was that it fit over the boss on the diffs and if you noticed i uses 2 ring gear diff sides (the flat side of the houseing). i used wheely king hubs on this version and they work great. check out the droop tuber i ended up with the only thing that works better than this rig is my super. ![]() ![]() ![]() ![]() ![]() ![]() |
| | #11 |
| | #12 |
| wow that does look nice! |
| | #13 |
| Newbie Join Date: Feb 2007 Location: In the Shop
| Nice work on the axles! i like the PVC. How are the Wheely King hubs working with the Revo axles ? Did you have to do any modifications to get them to fit? |
| | #14 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| I added a 2.2 builds in the above sticky and added this one If anyone knows of any other decent 2.2 buildups, please send me the link in a PM.. Nice work |
| | #15 |
| Pebble Pounder Join Date: Feb 2007 Location: sunman
| I'm assuming that last pic is your super? is that a gear reduction you have bolted to the tranny? Can i get some more pics of that setup, i like very much. |
| | #16 |
| OOPS!!!! yes that is of my super, what it is a gear set up that makes the drive shafts turn in Opposite directions, front turns CW and the rear turns CCW, it reduces torque twist!! |
| | #17 |
| | #18 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| Pretty cool. You missing a digit? |
| | #19 |
| mxracer525: Yes i made it myself, i have a few bugs to work out of it and it should be good to go. http://s105.photobucket.com/albums/m215/plop182/ johnrobholmes: Yes, 7 years ago i got into a fight with a tablesaw as you can see it won. |
| | #20 |
| Thread Tools | |
| Display Modes | |
