Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: revo knuckle / steering issues
Old 01-22-2007, 04:25 PM   #1
Default revo knuckle / steering issues
I'm working on a sas maxx project and my steering rods are not fitting right. I have the steering rod connecting the two knuckles on the top outside of the revo knuckle horn. One problem I had is the screw head is rubbing the rim which a buttonhead screw should fix that. The second more major problem is where the heck does the pitman arm fit? It can't go on the top of the connecting link and under it seems impossible without bending it. Any ideas? Sorry about babbling. What axle gc do you have? I might just need to cut the stuts. I appreciate the help.
Thanks,
RCH
RCHunter is offline   Reply With Quote
Old 01-22-2007, 04:37 PM   #2
Colt Python/SR9c
TwistedCreations's Avatar
Tierod(wheel to wheel) goes in the middle of the 2... draglink(steering box to arm) goes on top.. at least all my steups have.. plus I have the arms flipped so that the tabs sit higher
TwistedCreations is offline   Reply With Quote
Old 01-22-2007, 05:06 PM   #3
I got the bulkheads relief cut for the tierod on top of the knuckle. If I put the tierod in the middle it's bent. What kind of clearence do you have? I'm running cut swamp dawgs btw. I have my axle set to where when my arms stopped drooping, I locked them there. Sounds like I need to lower my axles a bit. Thanks for the quick reply.
RCH
