Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: stampede trans to maxx diffs
Old 01-23-2007, 11:35 PM   #1
Default stampede trans to maxx diffs
HELP!!!!BUILDING MY 1ST ROCK CRAWLER...HAS ENYONE USED A STAMPEDE TRANS AND MAXX DIFFS?MY PROBLEM IS WHAT DRIVE SHAFTS TO USE SINCE THE PEDE TRANS AND MAXX DIFFS USE DIFFERNT SIZE OUTPUT YOKES...THANKS...THIS FORUM HAS BEEN VERY HELPFULL
WTFRIDE is offline   Reply With Quote
Old 01-24-2007, 12:09 AM   #2
you need to have a transmission out put yoke on the trany side and the diff out put yoke on the diff pinion side.
in other words, the tranny need a 5mm yoke and the diff needs a 6mm yoke.
you will need to grind the yoke on the tranny side down to fit up to the trany case.
iu will see if i can find a link for you.
ON THE FARM is offline   Reply With Quote
Old 01-24-2007, 12:12 AM   #3
this is what you need to do to the out put yoke to fit.
Shaggin' Wagon................The Begining of Stage 2
Old 01-24-2007, 01:06 AM   #4
thanks for the info and link
Old 01-24-2007, 06:13 AM   #5
i just used the maxx drive axels and made it to have to female ends ground down the parts that go to the tranny i also took my dremel and sanded a little off the tranny for clearance on the side with the spur gear i will post a pic later
usa1man is offline   Reply With Quote
