Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: How do you lock your axles?
Old 05-25-2004, 09:53 PM   #1
Default How do you lock your axles?
I was just wondering how you locked your maxx axles?
MaxxZilla is offline   Reply With Quote
Old 05-25-2004, 10:59 PM   #2
Default Re: How do you lock your axles?
traxxas spools
dn9979 is offline   Reply With Quote
Old 05-26-2004, 07:43 AM   #3
Colt Python/SR9c
TwistedCreations's Avatar
spools or JB weld
silly putty acts like a limited slip
TwistedCreations is offline   Reply With Quote
Old 05-26-2004, 11:37 AM   #4
Guest
Posts: n/a
I tried using RTV to see what kind of limited slip effezc I got, all it seemed to do is cause a tad more binging?? I dont see much effect, just wasted effort.. :(
Old 05-26-2004, 11:43 AM   #5
Heh, whoops, didnt know I could post without logging in. Minding my spelling P's and Q's I noticed I made a mistake, meant to say "binding" not binging, but guests cant edit their posts...
masterbeavis is offline   Reply With Quote
Old 05-26-2004, 05:22 PM   #6
Nish's Avatar
what are spools?
Nish is offline   Reply With Quote
Old 05-26-2004, 08:37 PM   #7
^^^^^^^^^^^^ a spool locks both axle shafts the they always spin at the same speed. I locked the diff. in my st with super glue.
BushWacker is offline   Reply With Quote
Old 05-26-2004, 10:14 PM   #8
sorry about that,I didn't mean how do you lock your diffs. I meant, how did you lock your axles, solid so it isn't IS any more.
Old 05-27-2004, 09:15 AM   #9
Colt Python/SR9c
you talking about the stock a-arms or just making your own axles?
Old 05-27-2004, 04:22 PM   #10
I think he means lock the A Arms from traveling. I found the best way to lock them solid is to put a tie rod in where the shock goes. It gives you a little adjustability and works well. Im a new guy but I catch on quickly. I always wanted to build a rig like this. And I must say I have found quite alot of help from you guys. So thanks in advance. :P :o
MrBeav is offline   Reply With Quote
Old 05-27-2004, 05:31 PM   #11
Thats what I've done, I was just wondering if anyone came up with something better.
Old 05-27-2004, 06:20 PM   #12
hey maxxzilla I thought you meant that in your original post but didnt want to look like an idiot. I have had a bracket cnc'd to mount where the original shock tower mounted with ears on each side to mount my lockout rods to. These look awesome and are a bolt on affair. you have to drill a hole in the ear for the rod because I figured everyone would have different length rod. I will try to post up a pic but my computer/connection suck. I can have you a set made if youre interested theyre 1/8" aluminum brushed finish. I also have a bracket for the bulkheads behind the shocktower above the input to the diffs where the stock chassis mounts. He'll make them both for around 35 -40 bucks cant remember exactly. I already paid to have the program drawn up and the designs loaded into the cnc machine. If you ever make ot to one of our get togethers you can see the set I have .
hackster is offline   Reply With Quote
Old 05-27-2004, 07:10 PM   #13
I need to get my damn truck running right first, the steering is still screwed.
Old 05-28-2004, 05:22 AM   #14
Colt Python/SR9c
i knew what he meant, just didn't know what route he wanted to take..either to use stock a-arms or make everything up like
Old 05-29-2004, 09:58 PM   #15
HOLY CRAP that is sweeeeeeet :o
Did you build that?
Cavatude is offline   Reply With Quote
Old 06-06-2004, 04:30 PM   #16
Colt Python/SR9c
sorry aint checked this post in awhile..THANKS and yes i built it
here it is done and screwing around
