Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Like Tree1Likes
Thread: A complete start to finish Maxx build.
Old 04-08-2007, 08:40 PM   #41
it has links on it so they act like limiters, and how he has his setup, it uses huge ballends to connect the axles and they can only twist so far, so either way, he could easily have 75 or more degrees of flex. I say go rock pleazer for this, they are such an awesome body :-P
1/18th_Nylint_Auzzy is offline   Reply With Quote
Old 04-08-2007, 08:42 PM   #42
sfrankland's Avatar
No it is not max flex. It will goes past 90 up until the drive shafts bind up on the center shaft. I was running it some tonight and will be installing shocks tomorrow just to limit the flex. I will most likely run dual rate springs and a light oil.
sfrankland is offline   Reply With Quote
Old 04-08-2007, 09:11 PM   #43
wow that killed my theory lol, it goes past 90 with the ball links? how did you achieve this?
Old 04-08-2007, 09:20 PM   #44
sfrankland's Avatar
The rod ends are only on the links not on the shaft itself. The shaft is free to spin 360 degrees. The links will allow the shaft to rotate and with both ends free to turn you are going to the limit of all four ball ends. I figure that each rod end has about 25 to 30 degrees of movement in them. Take that into account by the time they max you will have 100 to 120 degrees of rotation. The links only lock the shaft from sliding front to back and to add some strength to the design which it doesn't really need. I am going to mount shocks tomorrow to limit the flex.
Old 04-16-2007, 11:58 AM   #45
jeepster26104's Avatar
How does it act as for keeping the axles parallel? Maxxes can really torque things.
jeepster26104 is offline   Reply With Quote
Old 04-16-2007, 03:30 PM   #46
sfrankland's Avatar
It doesn't suffer from much torque twist. My biggest problem right now seems to be my lathe motor stalling out. I still need to fine tune the layout and I will be adding some shocks to limit flex and fight what torques twist there is.
Old 08-09-2007, 01:06 PM   #47
best post on here! i have been thinking of ideas to make solid maxx axles and i was thinking of a similar design, now i can start my custom crawler im thinking about an e-maxx tranny with 2 55t's. and do you think it would be ok to MIG weld the solid axles?
crawlerkid3 is offline   Reply With Quote
Old 08-11-2007, 12:13 AM   #48
Some awesome work there! like the build and the truck!! nice job!
truegaintfree is offline   Reply With Quote
Old 08-27-2007, 08:14 PM   #49
can i plz get help on how to mount the lower links of a 4 link to these style axles?
gasshead is offline   Reply With Quote
Old 08-27-2007, 09:30 PM   #50
Love the thread dude. I might can build some axles like that seance there are some great photos. Keep us updated.
curdogexpress is offline   Reply With Quote
Old 09-03-2007, 12:18 PM   #51
sfrankland's Avatar
The build sort of got pushed to the back burner with summer holidays and reno work to the house. Now that the long weekend is over I should have more time to get back to building. I have soem chances in mind for the future.
Scott
Old 09-13-2012, 10:39 AM   #52
Default Re: A complete start to finish Maxx build.
Originally Posted by sfrankland View Post
Next I drilled my washers on my drill press with a 1/4" drill bit and then ran a 1/4" bolt down through the hole to hold all the washers together while I drilled the second hole. Next I took a drill with a 1/4" bit and elongated the hole so that it would allow the 1/4" rods to be set on an angle to the washer.
Use a ruler to set the length and
Attachment 27682
an angle gage to set the angle.
Attachment 27683
By drilling the washers and cutting the rods a little longer than what I needed I was able to clamp the extra on the ends into a vise.
Attachment 27684
By installing your knuckle the other rod is automatic set to the right angle and offset. I brazed my rods and the heat had no affect on the plastic knuckle.
Attachment 27685
I'm wanting to build axles as well. What angle do I set these up? Also , How long are they?
Thanks,
-Gary
gary is offline   Reply With Quote
Old 11-14-2012, 05:09 PM   #53
wow all i can say is badd ace thats a rad crawler
koupe88 is offline   Reply With Quote
Old 12-01-2012, 06:27 PM   #54
now im gonna make me a super class crowler this one gave me the push i needed lol in workin on my proto type axles now out of plastics for mock up
Old 01-03-2013, 08:32 PM   #55
Something
crazy81's Avatar
Hey hate to break this to you, but I think this thread is dead...
crazy81 is online now   Reply With Quote
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
