Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: What Would Happen?
Old 02-17-2007, 08:18 PM   #1
Default What Would Happen?
I was wondering what would hapen if I put a 48 pitch spur gear on an E-Maxx tranny. I'm wondering this because I have some really fast motors in my Maxx and I'm trying to go with the lowest gear ratio to try to slow it down.
ThanX,
Krystopher
Toph is offline   Reply With Quote
Old 02-17-2007, 08:20 PM   #2
Colt Python/SR9c
TwistedCreations's Avatar
Then slap a GD600 unit on it.. That will slow it down
TwistedCreations is offline   Reply With Quote
Old 02-17-2007, 08:20 PM   #3
thats the pitch, try telling us the tooth count now.
clod booster is offline   Reply With Quote
Old 02-18-2007, 07:45 AM   #4
There are 87 teeth. What exactly is a GD600 and where can you get one?
ThanX,
Krystopher
Old 02-18-2007, 10:25 AM   #5
Im running 72 spur and 8t pinion. It's really slow.
tapped-out is offline   Reply With Quote
Old 02-18-2007, 10:52 AM   #6
ThanX,
Krystopher
A GD600 is a gear reduction unit for an airplane. you can get them at towerhobbies.com
EastCoastCrawlers is offline   Reply With Quote
Old 02-18-2007, 11:17 AM   #7
I also have a 72 tooth spur gear. It works well but the motor is Jhonson 550 size motor and it has more torque and rpms plus it's faster than the stock 550s. So I'm trying to get the lowest gear ratio so I get the torque and rpms, but not the extra speed. How do you install a GD600?
ThanX,
Krystopher
Old 02-18-2007, 12:26 PM   #8
im running a 70 and 12 , both are 32 pitch. It is very slow! trust me
maxxcrawler309 is offline   Reply With Quote
Old 02-18-2007, 12:30 PM   #9
chevellian's Avatar
It bolts onto your moterplate,where the moter goes, then your moter bolts to it. you will have to turn down the output shaft of the gd600 to accept a stock pinion. if you do not want to turn it down yourself I can help you out. I had one layin around here for a spare that was ready to go, but I can't seem to find it.
chevellian is offline   Reply With Quote
Old 02-18-2007, 12:48 PM   #10
Thanks for the info. I'm not real sure how to turn down an output shaft, so help would be appriciated.
ThanX,
Krystopher
Old 02-24-2007, 10:10 PM   #11
if you have access to a lathe you could have somebody do it. If not you could stick it in a drill press a file the shaft down to 1/8. Your other option is drill out the pinion.
