Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Pro advise Please, tweak tune suspension
Old 02-24-2007, 03:58 AM   #1
toy4crawlin's Avatar
Default Pro advise Please, tweak tune suspension
Help advise Please Too Much Tork Twist
Ok I have spent half the day reading , searching, looking at pics of rigs and checking out the new crawler chassis, I found the thread on how to avoid tork twist Which really did not help explain very well, Found the thread that says how to set up Links, but there were NO pics,
& the other 9 hrs of the day building
so here's my set up before and after,
I keep'd the angle of the shock the same, just lowered and changed the shock from e-maxx to savage, was 1" travel now it's 1 5/8 travel shock
I'm getting a lot more tork twist
the spring was soft, so I added a heavier one, but can buy stiffer ones
ANy pros have PIctures of links and shock set up that work ?
Apreciate your advise
PICTURES TELL A THOUSAND WORDS
before pic 1 & 2
pic 3 after
toy4crawlin is offline   Reply With Quote
Old 02-24-2007, 08:12 AM   #2
Colt Python/SR9c
TwistedCreations's Avatar
so you have alot more torque twist after you installed the Savage shocks?
That should tell ya something
ditch the savage shocks, run thicker oil also
also, the further you move the shocks out towards the wheel, the better
TwistedCreations is offline   Reply With Quote
Old 02-25-2007, 12:18 PM   #3
not a pro first build but this seems to have mininmal torque twist work good. Springs 3 are stock red 1 is blue dule rate spring just had it laying around.
nothig to do w/torque twist but just flex A shot
tapped-out is offline   Reply With Quote
Old 02-25-2007, 05:07 PM   #4
Keep it real
Tanis's Avatar
One thing I see is, the angle of your upper links. Try raising them up off the axle, so your upper links don't angle upward toward the chassis. Try to get them level with the ground, or better yet, angled down from the axle to the chassis. This fixed the torque twist on my buddies maxx. 100wt oil is good.
Tanis is offline   Reply With Quote
Old 02-25-2007, 05:27 PM   #5
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Lower your ride height. That will help a good bit right off the bat.
JohnRobHolmes is offline   Reply With Quote
Old 02-27-2007, 10:17 PM   #6
Thank you , I have not moved the upper links yet, but I did drop in the red springs from the max shocks in the 1st & 2nd pics then used 60 weight silicon , it Helped A lot and it twists to a full 90
When I build my new crawler I'll do better on the links
Great feedback thank you
Crawl On
Old 02-28-2007, 04:13 PM   #7
YEa I agree,
I'm going to see what I can do to Lower the chassis and then limit travel, because it is twisting to a Full 90* !
