Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: E MAXX trans ???
Old 02-24-2007, 02:13 PM   #1
Default E MAXX trans ???
Do I want to push or pull the spur gear with 1 motor ??
morehorsepower is offline   Reply With Quote
Old 02-24-2007, 02:35 PM   #2
I might be missing something, but I don't see how it would matter, especially considering you will be reversing from time to time.
Smib is offline   Reply With Quote
Old 02-24-2007, 03:55 PM   #3
Colt Python/SR9c
TwistedCreations's Avatar
do what?
TwistedCreations is offline   Reply With Quote
Old 02-24-2007, 05:36 PM   #4
31st place in 2006 Nats!!
toyofast's Avatar
I prefer to drag and lift.
toyofast is offline   Reply With Quote
Old 02-25-2007, 09:19 AM   #5
Okay if I use 1 motor and cut the motor plate off will the motor pull the spur or push the spur ??
Old 02-25-2007, 10:01 AM   #6
Shut up Dave
jetboat's Avatar
I think I might understand what he is trying to say and the answer is it doesnt matter, the motor turns the same direction no matter which mount its on
jetboat is offline   Reply With Quote
Old 02-25-2007, 10:19 AM   #7
Couldn't have said it better myself. The only way it would make a difference is by making your rig go forward or backwards.
Krystopher
Toph is offline   Reply With Quote
Old 02-25-2007, 10:30 AM   #8
Colt Python/SR9c
Ohh, so you want to know to either go clockwise or counterclockwise
That depends on what motor your running and which way your trans is sitting.. The gears in the trans are a straight cut, so it makes no difference if it is running forward or backward.
If you were sitting in the truck, you want the driveshafts to spin clockwise
Old 02-25-2007, 07:58 PM   #9
Thanks guys I will get on with my build now .
