Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: new maxx crawelr!!!!!!! Restamaxx...
Old 03-10-2007, 06:58 AM   #1
Default new maxx crawelr!!!!!!! Restamaxx...
looking to create a new max crawler using a txt cutted chassis, stock emaxx axle, savage shocks, emaxx tranny, evx esc, 2 integy 65t, 9th pinion and 72 th spur... actually losi Lst tires
look this buid up..
blue one it's mine Cramaxx... and the green ones it' the one i'm completing...
any idea? suggestions??
many thanks!
naftausa is offline   Reply With Quote
Old 03-10-2007, 07:47 AM   #2
I think it looks great!! Whats the wheel base? Keep up the great work!!
Krystopher
Toph is offline   Reply With Quote
Old 03-10-2007, 08:49 AM   #3
Cramaxx
here there is the cramaxx build up...
the wheel base it's about 21"
Old 03-11-2007, 12:03 PM   #4
Thumbs up
these are the perfict pics for someone looking at how to mount the links
Thanks,
Jesse
Why Be Low is offline   Reply With Quote
Old 03-12-2007, 12:38 PM   #5
cool man!
BrandonW is offline   Reply With Quote
Old 03-13-2007, 11:18 PM   #6
in this pic how are the shocks mounted to the links? if you don't mind me asking
usa1man is offline   Reply With Quote
Old 03-14-2007, 08:17 AM   #7
the ammo are mounted on the link by a hole in the links and a screw passing.
Old 03-17-2007, 10:58 AM   #8
What kind and dimention of tube do you use?
Great job!
Sunkist is offline   Reply With Quote
Old 03-18-2007, 08:58 AM   #9
i used a 10mm diameter allu, worj to 6 mm to the end and 8 in the middle.. covered by thermo retract materials.....
Old 03-18-2007, 12:46 PM   #10
nice build. you goin with ind. 4 wheel steer? looks like the COG is a little high with them two 65t's up top, or is it not too bad? 21"wb that things a monster.
mxracer525 is offline   Reply With Quote
