Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: My first build.
Old 03-20-2007, 05:23 AM   #1
Default My first build.
Click the image to open in full size.Here are some pics. of the first build.Click the image to open in full size. Click the image to open in full size.Click the image to open in full size.Click the image to open in full size. Click the image to open in full size.
xjfam is offline   Reply With Quote
Old 03-20-2007, 12:16 PM   #2
Looks like a great start. I only have 2 suggestions. I'm not a comp crawler or anything so I don't know it all, but I would move your bottom links to the inside of the chassis so they don't hang up on a rock and it will give your links more double triangulation. And second I would mount your shocks on the axles as close to the tires as possible. Other than that I wouldn't change a thing.
What tranny do you plan on using?
mazdaparts is offline   Reply With Quote
Old 03-20-2007, 05:58 PM   #3
What does mounting the shocks on the axle do? More stability?
Old 03-20-2007, 06:44 PM   #4
I'm not exactly sure but I think that it helps eliminate torque twist. Otherwise it looks really good!!
Toph is offline   Reply With Quote
Old 03-21-2007, 07:07 PM   #5
Thanks for the input. I moved the links to the inside of the frame and they look good. Next I am going to work on locking the axles, getting the trans, and ESC.
Old 03-22-2007, 06:29 PM   #6
i'm workin on my 2nd maxx crawler also, wat kind of esc/motor combo u running? looks like a good chassis design, i was thinkin of goin that route. looks good.
mxracer525 is offline   Reply With Quote
Old 03-23-2007, 05:08 AM   #7
MXRACER525 I am not sure yet. I have been reading all the threads I can to see what I should use. Tekin rebel 2 seems good for the esc. Motor sounds like a 55T Lathe, don"t know much about motors yet. And the trans. I may use a RC4WD R2. Let me know if you have any thoughts or questions.
Old 04-11-2007, 08:33 PM   #8
Here are some more pics of the truck.Click the image to open in full size.
Old 04-11-2007, 08:39 PM   #9
I will try this again.
Old 04-12-2007, 05:44 AM   #10
Are you going to keep your wheels that color? For the lathe motors it's the higher the number the less speed and more torque. The lower you go it's the less torque and more speed. They go from 35t, 45t, 55t, 65t, and 75t. Hope that this helps.
Krystopher
Old 04-12-2007, 08:24 PM   #11
I don't know about the wheels yet. Thanks for the input on motors. I need the trans and speed control next and I think I will be ready for a test run.
Old 04-13-2007, 02:44 PM   #12
i would go with two 55's, you still have a moderate wheel speed with those
ian48065 is offline   Reply With Quote
Old 04-13-2007, 02:59 PM   #13
I put in two 55t's in my first Maxx and told my cousin that it was slower. This is what he asked,"You made that slower?". So you get the picture, that yes you can get good wheel speed with two 55t's.
Old 04-14-2007, 05:40 AM   #14
I have been looking at the RC4WD R2 trans. It is geared very low and is very tough. Then I could use a single 55t motor.
Old 04-14-2007, 06:25 AM   #15
I have an R2 tranny on the way for my X-Factor build. they look extremely strong and they are low geared. I will be running a 75T lathe in my X and possibly a GD-600. I will see when the trans finally gets here....... (sorry thats my favorite smilie )
Old 04-14-2007, 06:37 AM   #16
If it gets here soon let me know what you think of the trans. Any great ideas on an ESC? Tekin rebel 2 ? What do you look for when purchasing one?
