Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: emaxx trany questions
Old 03-07-2005, 11:30 AM   #1
Default emaxx trany questions
I picked up an emaxx trans for a txt project, my question is does the emaxx tranny make a clanking noise. in functions but its load as hellllo. thanks.
Magic is offline   Reply With Quote
Old 03-07-2005, 11:34 AM   #2
2006 2.2 National Champ
BENDER's Avatar
It shouldn't be, is it locked in first gear? Kind of sounds like you're in between 1st and 2nd gear, make sure the shaft, that switches gears, is pulled all the way out.
If all that is good, you may have stripped the idler gears in the tranny. I've had to replace mine a couple times.
BENDER is offline   Reply With Quote
Old 03-07-2005, 01:29 PM   #3
cool, i will check it out in a bit. it works in first and second, its just load and clanky when it runs. thanks.
Old 03-08-2005, 05:12 PM   #4
Get off my lawn!
microgoat's Avatar
loud is fairly normal, if you're talking about gear noise. clanky? could be a bad bearing, or just the normal slop in the selector mechanism. tear it down and have a look-see. there's only 7 moving parts in there.
microgoat is offline   Reply With Quote
Old 03-08-2005, 06:17 PM   #5
31st place in 2006 Nats!!
toyofast's Avatar
Even if it's locked in 1st you'll still notice a bit of slop which can cause a small amount of "clunking" sound. Best way to solve it is to kill off the slop. Any of the RCRG rigs that run a Maxx tranny have had the trannys "fixed" to have ZERO slop. It's tighter than a TXT tranny as far as amount of slop.
toyofast is offline   Reply With Quote
Old 03-08-2005, 06:27 PM   #6
So how do you "fix" the slop then?
HULK is online now   Reply With Quote
Old 03-08-2005, 11:17 PM   #7
toyofast's Avatar
If I don't have something posted up by Saturday.... just remind me and I'll do my best to post some pictures/write-up of it.
Old 03-09-2005, 12:07 AM   #8
06 Super National Champ
JasonInAugusta's Avatar
From the other maxx tranny thread on this page.
Originally Posted by JasonInAugusta
To lock the tranny I drilled a couple of holes through the slider that engages 1st and 2nd.
Then I put screws through the slider and into the gear.
This not only locks the tranny into first (can do the same thing by locking the shaft that moves in/out of the tranny) but it also gets rid of all the slack in the E tranny.
JasonInAugusta is offline   Reply With Quote
