Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: wheel compatibility question
Old 04-17-2007, 01:22 PM   #1
Default wheel compatibility question
hey, im new to this whole crawling scene...well, im building my first crawler and im looking at tires and wheels...i like the moab xl 40 series tires...well, thw wheels i want to run with them, im not sure if they will work on my e maxx....they are the proline cheyenne bead loc wheels designed for the xl moabs...they dont specifically say they are fpor the e maxx, but they are the 23mm hex hubs... here's a link... http://www2.towerhobbies.com/cgi-bin...&P=SM&I=LXLPW9
lemme kno if this will work for my truck...
bagged92sdime is offline   Reply With Quote
Old 04-17-2007, 03:04 PM   #2
sfrankland's Avatar
They will work. You need the 23mm hex adapter to run them on your truck. http://www.prolineracing.com/product...product&id=166
sfrankland is offline   Reply With Quote
Old 04-17-2007, 08:10 PM   #3
You can run any tire and wheel setup on any rig. Just as long as you have the right adapters.
Toph is offline   Reply With Quote
Old 04-17-2007, 10:00 PM   #4
jeepster26104's Avatar
Check out the crawler store.
(Part #CLD2MX)(Thunder Tech #DEL-CB03). You can run Pro-Line 40 Series Commando Bead-Loc and Pro-Line 40 Series 23mm Cheyenne Chrome Wheels with these adapters. Includes four each 14mm to 23mm hex adapters and 4 each circular rings. These work in conjunction with Part #CLD2MX, so you must purchase or already own Part #CLD2MX to use these.
And only 15 smackers.
jeepster26104 is offline   Reply With Quote
