Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Robinson Racing gear question
Old 04-20-2007, 10:48 PM   #1
Default Robinson Racing gear question
Ok, so I just ordered some gears from Tower hobbies. I ordered a 72t spur gear and 2 9t pinion gears. I just put them on, but even when they're adjusted (I used the plastic bag between the gears to get them set), they seem to have a little more friction than normal. I know for sure that the pinion gears are 32p, but the spur gear did not say. So would the spur gear being a different pitch cause them to chatter more and feel a little more resistant? Or is that just what upgrading gears/using metal gears does? I don't want to destroy the gears, so if anybody can help me out here, it would be GREATLY appreciated.
bagged92sdime is offline   Reply With Quote
Old 04-20-2007, 10:57 PM   #2
TLTCrawlin's Avatar
em 72t sounds like it should be emaxx aka 32 pitch. 32 and 48 wont even mesh together at all, it will just grind if too lose/lock up if too tight.
what I do is bolt the motor up, push gears hard against each other, so its tight, and then slightly pull back, semi-tighten motor screw (have one fully tightened so you can move the gear mesh slowly on one side) and if it feels ruff, loosen the semi-tight screw, pull back a lil more. and do that til its perfect. My TLT w/ pede trans doesnt make nearly any sound from the trans now cuz the gears are broken in!
TLTCrawlin is offline   Reply With Quote
Old 04-20-2007, 11:09 PM   #3
An Emaxx is 32 pitch so if you have 9T pinions @ 32 pitch it sounds like adjustment. If they (pinions) are anything like the RC4WD ones I sell they have a bevel to tthe teeth where they were machined less and less towards the set screw. So like the other guy says.......do some adjusting
Stampede gears are 48 pitch so its a big difference
FinishLineRC is offline   Reply With Quote
Old 04-21-2007, 12:47 AM   #4
I have that exact setup, except i run one 55t lathe motor so i only use one 9t pinion. The stock is easier to get the mesh right, but after a little while you can get the 9/72 to work . Took me a few adjustments till I got it to the perfect setting.
4x4dodge is offline   Reply With Quote
Old 04-21-2007, 12:54 AM   #5
TLTCrawlin's Avatar
oh I forgot your running two motors. Never tried that before, good luck LOL!
Old 04-21-2007, 01:05 AM   #6
set one at a time.
set one then take it off put on the other, set it. then put the first one back on. this way the mesh will be perfect.
ON THE FARM is offline   Reply With Quote
Old 04-21-2007, 01:08 AM   #7
TLTCrawlin's Avatar
what ^ then whats the prupose of setting the first one in the first place!!!!
Old 04-21-2007, 05:23 PM   #8
He just means to take the pinion off the first motor, leaving the motor where it is.
bigchev is offline   Reply With Quote
Old 04-21-2007, 05:33 PM   #9
TLTCrawlin's Avatar
Oh in that case good idea for dual motor runners!
