Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Stampede to Maxx
Old 04-21-2007, 11:33 AM   #1
Default Stampede to Maxx
I'm not sure if this is the place to post this question, but I have a stampede tranny and T-Maxx diffs, is there a way to get a driveshaft from the tranny to the diffs? Would a Jato drivshaft work with some modifications? Also the wheelbase is gonna be longer than a 2.2 with a stampede tranny will there be a length issue with that size of driveshaft? Any help would be great thanks.
UBER is offline   Reply With Quote
Old 04-21-2007, 01:53 PM   #2
As to whether this is the correct forum depends on what ur building. But most people on here won't hold back any information anways, even if it isn't for a crawler. Now on to an answer: I am placing a stampede tranny in a tmaxx chassis (custom upper deck) using the stock driveshafts that normally run from diff to hub carrier. These driveshafts are going to run from the tranny to the diffs at front and rear of vechicle with no length problems, like you are saying i think.
papasnachez is offline   Reply With Quote
Old 04-21-2007, 01:55 PM   #3
I also have a stampede tranny in my TXT setup. Wheelbase is 17 inches using revo driveshafts. Thats pretty long, not much more than 1/4 inch of insertion, but no problems. They don't fall out and they handle the torque. Just giving you some more comparisons since I don't know exactly what your building or exactly how long of a span you are covering.
Old 04-21-2007, 10:03 PM   #4
I am in the same spot. I haven't tryed to do it yet though. I have a full set of diffs from a e-maxx and would like to use my stampede tranny to build a crawler. Can I use the outer long driveshafts from the e-maxx with a stampede yoke to the tranny side?
bro460 is offline   Reply With Quote
Old 04-21-2007, 10:29 PM   #5
You can use the E/T-Maxx outer shafts to go from the Stampede transmissinon to the diffs. For the Pede Transmission side, you need to make sure that you are using Maxx Diff out put yokes, not the Maxx Trans yokes. Just grind down the back edge so the hole for the screw pin on the yoke will line up with the screw pin hole on the diff.
Here is a pic showing a stock yoke compared to the modified yoke for the Pede trans.
Sorry for the blury pic.
TMXONR is offline   Reply With Quote
Old 04-22-2007, 12:57 AM   #6
http://i22.photobucket.com/albums/b346/TMXONR/P1010259.jpg[/IMG]
i have done this but you may also want to sand down the gear box half for clearence issues manily the side the spur is on
usa1man is offline   Reply With Quote
Old 04-24-2007, 01:37 PM   #7
Sweet Dude, Now that's the answer, with pic's even. Much appreciated.
Old 05-07-2007, 08:09 PM   #8
Just mounted up and built my main chassis. It's easy. I'll send you my pic's as soon as I figure out how to use the photo posting thingy.
Old 10-31-2010, 06:36 PM   #9
I did the same mod to my tranny and it works great!
White Stripe is offline   Reply With Quote
Old 11-10-2010, 05:02 PM   #10
Same here, works really well.
awdtsi is online now   Reply With Quote
