Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Mounting 2.2" wheels on a Maxx?
Old 03-15-2005, 05:45 PM   #1
Default Mounting 2.2" wheels on a Maxx?
Anyone ever done it? I am thinking if I can modify the stock 14mm hex's to 12mm, I can run 2.2" rims on my maxx. Just wondering if there's any other ways to do it. I want to run the new All-T's on my new nitro maxx project truck.
CrawlinForLife is offline   Reply With Quote
Old 03-15-2005, 06:27 PM   #2
Just grind some material off of the stock hex. As far as I know, no one makes adaptors.
I don't think that 2.2 rims will fit over the knuckles.
CustomCrawler is offline   Reply With Quote
Old 03-15-2005, 06:54 PM   #3
Colt Python/SR9c
TwistedCreations's Avatar
with grinding the hexes down, you may get into that hex pin. if not, you will weaken it very much. as for the knuckles, i'm not sure if the rims will fit over the knuckles.I have a set of 2.2 rims outside and my maxx axles are tore apart. so i will measure it for ya to make sure
TwistedCreations is offline   Reply With Quote
Old 03-17-2005, 11:31 PM   #4
with ofna 2.2s they have a ton of offset. they work great on a tlt. as far as adapters. drill out a 12mm hex and hope.
Magic is offline   Reply With Quote
Old 03-17-2005, 11:51 PM   #5
use one of these and it will work
http://www2.towerhobbies.com/cgi-bin...?&I=LXCAN2&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXCAN0&P=7
Old 03-18-2005, 07:16 AM   #6
Colt Python/SR9c
yeah i went out and measured last night( forgot to for ya)
but the Maxx knuckles and a set of 2.2 rims i have are both the same measurement. the rims will not fit over the knuckles unless you do some serious trimming/shaving. If you get into all that then, i would really think your going to run into strength issues
Old 03-19-2005, 12:51 AM   #7
you can shave a small amount off of the maxx knuckle to get them to fit...it will not effect strength to greatly.
cborrowman is offline   Reply With Quote
Old 03-19-2005, 09:04 AM   #8
Hmm those OFNA wheels look nice, But I want to narrow the truck up. Back in the day I had the first gen maxx, cut the stock arms shorter, drilled out the ends for the pillow balls, and using ofna adaptors mounted 1/8th scale tires on it. It looked sweet. I was kinda hoping to do the same to this one, but use the larger All-T's this time, bringing them in closer for a more scale look.
Old 03-19-2005, 11:53 AM   #9
Colt Python/SR9c
Hmmmm, that's different ideasounds like a little work is involved, but making a 2.2 sized maxx.. i kinda like it... I may just try that route instead of a TLT for my son.If you decide to do it, please post up what your doing. When you narrowed your last maxx, how short did you cut your arms?
Old 03-20-2005, 08:26 AM   #10
Well I started with a Non-widemaxx maxx, and then took about an inch off each side. So it was 2" narrower, then ran 1/8th scale buggy wheels and tires on it with the ofna adaptors.
I need to find another set of non-widemaxx arms to do it to the one I have now.
The cool thing is that the All-T's are 5.5" according to their site, and the stocks are 5.75" so I won't be giving up that much height.
Old 03-20-2005, 10:07 AM   #11
Colt Python/SR9c
ok, yeah i think i have 2 sets of non wide arms outside...I think one set if just out there collecting dust
Old 03-29-2005, 01:23 PM   #12
Small Scale Emaxx
I just used alloy rims and shaved a very small amount off the inside with a lathe. They work like a champ.
skyjacker_rc_club is offline   Reply With Quote
Old 03-29-2005, 01:54 PM   #13
Colt Python/SR9c
Nice work Brian
Old 03-29-2005, 02:09 PM   #14
Thanks
