| | #1 |
| Quarry Creeper Join Date: May 2004 Location: Boobslando, florida
| Does anyone have any photos of a Locked Emaxx Diff or is it the same process as the loked diff in the tutorial section of this site....?????????????????????????????? 8O |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Apr 2004 Location: Louisiana
| YES |
| | #3 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| i dont have a pic of it and can't think right now about the article your talking about off hand..but if your not using spools then take the diff apart. you will see the spider gear carrier with 4 screws holding the ring gear on.. take those 4 screws out..now pop the spiders out and the other axle..so you should have an empty carrier and 2 side axles and spiders in your hand now..wash everything off real good so the JB weld will stick..as you put it all back together( spiders and 1 side axle in) cram in some JB weld now..rotate the spiders and stuff around to get it really packed in there..leave some at the top also, that way the other stub axle will be welded also( if not, you will only have 1 wheel drive |
| | #4 |
| I prefer the "Moldy Twinky" lockers |
| | #5 |
| Quarry Creeper Join Date: Jan 2004 Location: CSU, CO
| Picture from DirtPigs Rockroach http://www.outerlimits4x4.com/PHP_Mo...ight=rockroach |
| | #6 |
| but where in that post is a pic that shows a locked diff? :? |
| | #7 |
| Sorry I didn’t read the post right. That link is for a tranny not a diff. |
| | #8 |
| hmmm I think I managed to get it right cuz I stuffed a bunch of JB weld till it came out of every crack and my rear end is rock solid.... and im going tomorow to pick up a 76t R&R spur gear to run with my 9t R&R pinions..... |
| | #9 |
| TCS Team Manager ![]() Join Date: Feb 2004 Location: on a Big Rock
| For locking maxx diffs use a spool http://www2.towerhobbies.com/cgi-bin...XSP76&P=ML I will buy the 8t pinion off you! Do you think you can get more? |
| | #10 |
| Newbie Join Date: Dec 2006 Location: minnesota
| I should lock both diffs with spools right? thanks |
| | #11 |
| Live,Eat,sleep RC ![]() Join Date: Nov 2005 Location: Oregon
| Yes use spools. |
| | #12 |
| Newbie Join Date: Dec 2006 Location: Cotati
| yes lock both or u will snap axles left and right |
| | #13 |
| Quarry Creeper Join Date: Nov 2005 Location: fairfax
| i did a "how too" write up a while back. i have it saved to file. if you would like i can email it to you. i have a "how too" on locking the tranny up as well. i did have them up on my web site but it's going through a rebuild session right now if you want PM me with an email and i'll send it to you |
| | #14 |
| Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
| I use the Expoy method. It is pretty much the same as the JB weld method, but Epoxy is faster. I use 5 min epoxy. you just squirt some epoxy in, don't worry about the two parts being mixed prior, because you will spin the spiders to mix it. You will put the ring gear back on after squirting epoxy in, dont screw it together yet. spin the output yokes, take the ring gear off, and squirt some more epoxy in, put the ring gear on, spin the output yokes again, make sure there is no epoxy in the screw holes, put the screws in, and you are ready to go the same day, instead of wating overnight. |
| | #15 |
| Shut up Dave ![]() Join Date: Dec 2005 Location: Romeotucky
| if you want simple go with teh spool, takes 15 min to install and you'll never need to worry about them. |
| | #16 |
| Quarry Creeper Join Date: Feb 2006 Location: Shillington
| The spools are only $12 each and are well worth the money. You have to be careful when you get bound up but If you use common sense your axels will last. |
| | #17 |
| Thanks |
| | #18 |
| Rock Stacker Join Date: Apr 2004 Location: Bamberg / Germany
| If you need some installing pictures of the Traxxas spool: --> Click here! (and the next 4 pictures) I´ve got 2 spools and 2 locked diffs in my E-Maxx 8x8, everything works fine. The two front diffs are locked with Pattex "Power Plasticine", this thing gets as hard as a rock when it´s dried out... Manuel |
| | #19 |
| thank you |
| | #20 | |
| Rock Stacker Join Date: Apr 2007 Location: barstow
is that 10.99 for two or 10.99 for 1 diff locker | |
| Thread Tools | |
| Display Modes | |
