| | #1 |
| Rock Stacker Join Date: Mar 2005 Location: natick mass
| well i have finnally finished my maxx crawler... here are the specs duratrx auto sport esc hitec aggressor 3 channel fm non comp radio venom reciever pack radio shack cooling fan for esc hitec 645mg servo in front traxxas 2055 servo in rear lst tires and rims custom cvd center driveshafts (they really do hold) 9, 72 gearing locked diffs with jb weld mip cvd's in rear and duratrax in front tranny locked in first and slop removed 7 cell gp3300 batts hpi ford bronco body rpm sus arms revo rod ends on links i still need a motor look here to help me : GRR i fried my motor. please help FAST!!! pics: ![]() ![]() ![]() ![]() ![]() pls leave some feedbak matt g |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Nov 2004 Location: Redding, CA
| looks allright. you could probly mount the battery down a little lower in the front, and is it going to have enouph gearing with out a gear reduction? |
| | #3 |
| thats a good idea about the batt, i will try it soon ya i learned i need a gear reduction because i fried my team orion rush 23 turn today :neutral: |
| | #4 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| looking good.. did JK put duct tape on your front driveshaft? on the reduction- I got my GD600 from Towerhobbies and i run an 18t on the motor( it comes with the gd600) and i ran my 9 tooth pinion on the reduction unit to the spur gear. it has tons of torque..i run a 27t johnson motor. i would suggest a 12 tooth pinion instead as it would be a little better in the wheelspeed. i will change mine to that once i get one. also, if you do decide to get a GD600, shoot for a reversed Magnetic Mayham motor or a motor that can be set to 0 degree timing.. the GD600 reverses it all so you either need a reversed motor to run the right way or flip the wires on your motor also, if you run a 600, you DO NOT have to make the holes in the motor plate on the tranny any bigger. instead, there is plastic on reduction that you can just shave it off and have a flush fit. the bearing does not go through that part, so no need to worry about that |
| | #5 |
| Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| Beef It looks like MudCow's, which is a good thing. |
| | #6 |
| it should JK helped build it BTW matt- i seen your other post in the electrical forum...if you do get a lathe, there really is no need for a reduction as it is slow with just the motor... but you can do both.. if you do both, you will need to gear higher i also run a 72 t spur gear |
| | #7 |
| ya i cant thank JK enough for giving me the idea of this project, this is just my modofied version of his roach. i did all of the fabbing myself in only 2 weeks so i am going to run a GD-600 with 18t pinion on a reverse mag mayhem and a 12t pinion on the end of the GD-600 where it connects to the 72 tooth spur...... does that sound right? the duct tape on the driveshaft is.........holding it together because both sided are tapped and a screw holds it together.....but not in reverse.... that is where the duct tape and super glue comes in |
| | #8 | |
yes sounds good...the GD600 comes with a 48pitch gear ( which is the 18 tooth)..you will need to have the end of the GD600 turned down..either JK could help or mat and adam or whoever has a lathe.. i did mine very slowly with a dremel.its not perfect, but its close. i used a dial meter( what i use to set backlash in truck gears) to help me see where it was high and low... but try that gearing first, if its still too slow for you, jump to a 14 tooth instead of the 12 tooth... just remember, the GD600 uses 48 pitch gearing. so you will use the one that comes with it on the motor. then you can use 32 pitch gearing on the spur and 12t pinion. | |
| | #9 |
| ya i dont think jk can help me because he lives in australia and i am in the us.... i think i can figure out how too mill it down, how large is it stock? i am going to use a 13t pinion now that you recomend a 12 is a little too small |
| | #10 |
| well hell, i thought you was over in Aus. :neutral: I really couldn't tell ya how much to shave off, but i know it's close to half the size. You have PM( well here in a sec. you do |
| | #11 |
| Quarry Creeper Join Date: Feb 2005 Location: Indy
| the duct tape on the driveshaft is.........holding it together because both sided are tapped and a screw holds it together.....but not in reverse.... that is where the duct tape and super glue comes in Duct tape and superglue.....only in America!!!! Its a beautiful thing!!!!!! Joking aside, thats a good looking truck all the same!!!!!!! |
| | #12 |
| i just ordered a revo driveshaft so i can take that duct tape one out of the front |
| | #13 |
| Rock Crawler Join Date: Jul 2004 Location: Rexburg
| are you gonna bring it to the get together on the 16th? |
| | #14 |
| what get together and where? |
| | #15 |
| today i put my lst's on stock savage rims and while they could be narrower i think they are fine... i also put a tq3 radio in and took out my fm one (going in my buggy). i got the tq3 all wired up with a traxxas villan metal whip antenna for a boat (with antenna tube over it) now all i need is the 2 way momentary switch for my rear steer.... here are some pics TQ3 (shows my love for zip-tyes ![]() my alum wheel covers i made for my rims and my tq3 (just for looks has no use) ![]() lst's |
| | #16 | |
| | #17 |
| ya i might be able to go if i get some more info on it......time, address... |
| | #18 |
| | #19 |
| Pebble Pounder Join Date: Jun 2004 Location: Trenton,Texas
| That looks freakin awsome man, hey could you get a pic of the axle so i can see how you did it and all so i can see what i can do to mine and all, if you could that would be great. |
| | #20 |
| Thread Tools | |
| Display Modes | |
