Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Project "Manolo" progress. Pics inside!
Old 04-11-2005, 05:53 PM   #1
Location: World -> Europe -> Italy -> Umbria -> Perugia -> Assisi -> Petrignano di Assisi
Cool Project "Manolo" progress. Pics inside!
Hi,
My name is Andrea and i come from Italy. I'm new in this forum and i started a new Maxx Crawler Project called "Manolo". I have started from an old T-Maxx tranny case and axle, these are the first pics (made with Nokia 6600@640x480):
http://garrett.altervista.org/magazz.../Foto(367).jpg
http://garrett.altervista.org/magazz.../Foto(368).jpg
http://garrett.altervista.org/magazz.../Foto(369).jpg
http://garrett.altervista.org/magazz.../Foto(370).jpg
http://garrett.altervista.org/magazz.../Foto(371).jpg
http://garrett.altervista.org/magazz.../Foto(372).jpg
http://garrett.altervista.org/magazz.../Foto(373).jpg
http://garrett.altervista.org/magazz.../Foto(374).jpg
Tell me what do you think!
Sorry for my bad english and sorry if i make some mistakes
Garrett is offline   Reply With Quote
Old 04-11-2005, 05:57 PM   #2
looks like a good start to me.
mike is offline   Reply With Quote
Old 04-11-2005, 06:08 PM   #3
Default Welcome Aboard!
Looks Good! Clean work too! Good Job making that T-Tranny work for you. How long of a Wheelbase are you going for?
JakeTheAlligatorMan is offline   Reply With Quote
Old 04-11-2005, 07:25 PM   #4
RSI
look good to me... you might wanna use some cross bracing on the top of your frame.....
RSI is offline   Reply With Quote
Old 04-11-2005, 07:45 PM   #5
thats tight what thickness is it 1/4" ?
crunk crawlin is offline   Reply With Quote
Old 04-11-2005, 08:07 PM   #6
Great start, can't wait to see it finished.
MoabCrawler13 is offline   Reply With Quote
Old 04-11-2005, 09:25 PM   #7
It looks good, but your not going to be able to use that tranny. It has an internal clutch, which is bad. You want direct power right from the motor to the tranny, but with that one, it needs to spin the clutch fast enough for it to engage. Try to get your hands on an e-maxx tranny, since it'll fit the same, but work tons better. But besides that, looks great. I am also gonna start a maxx crawler. Good luck! Oh, by the way, Italians rock! \m/
thumpin15s is offline   Reply With Quote
Old 04-12-2005, 05:07 AM   #8
For Thumpin:
It's true, tmaxx tranny have 2 internal clutch, but i have locked it and tranny works equal than emaxx tranny, i don't know the ratio of emaxx tranny, the ratio of my tmaxx tranny is about 3:1
The thickness of the frame is 3mm, and the diameter of tubes is 6mm.
Wheelbase length??? I don't have any idea...i can make any length because i think to make myself the trasmission shaft, any suggestions????
Old 04-12-2005, 08:50 AM   #9
OHHH! Thats clever right there! Hey, in that case, you think you could tell me how you lock it? I have a t-maxx tranny sitting around that would be nice to use for my crawler!
Old 04-12-2005, 09:06 AM   #10
Colt Python/SR9c
TwistedCreations's Avatar
the ratio of the e-tranny is like 2.8:1 and the diffs are like 2.7:1
TwistedCreations is offline   Reply With Quote
Old 04-12-2005, 11:49 AM   #11
Looks like a good start!!!!!Have you thought of what body your gonna use????
Also...keep us updated!!!!
silvr_tung_devl is offline   Reply With Quote
Old 04-12-2005, 12:32 PM   #12
Lock the t-maxx tranny case is simple, there are two clutch to lock. The first is not a real clutch, its a bearing that force the gear to rotate in one only direction, in the other direction it slips. Just made 2 hole and lock it with screw at the other gear that not have this bearing (it is fixed directly to the primary shaft). The second clutch is the gear change clutch. Lock this clutch is simple like the first. Just lock the gear always with two screw at the metal wheel used for gear changing. Its a metal wheel that its linked with the gear changing arm linked with the servo. However, when i open it, i make some photos for you.
For Silvr:
I don't know the body that i gonna to use, for now i'm thinking at the frame
Old 04-12-2005, 04:30 PM   #13
I make some photos of the project progress, now tubolar frame is started:
http://garrett.altervista.org/magazz.../Foto(375).jpg
http://garrett.altervista.org/magazz.../Foto(376).jpg
http://garrett.altervista.org/magazz.../Foto(377).jpg
http://garrett.altervista.org/magazz.../Foto(378).jpg
Now my problem is the shocks. What kind of shocks is better?? I have T-Maxx shocks but i think they era too short. I like Savage 25 shocks but is difficult to find in Italy...suggestions???
Old 04-12-2005, 05:18 PM   #14
use the shocks you want, but i use some aluminum savage shocks on my maxx and i love it.
Old 04-12-2005, 11:37 PM   #15
I would go with the Savage shocks, try towerhobbies.com or integy.com
Old 04-13-2005, 04:04 AM   #16
Great looking work! I really dig the combo (tube and sheet) frame.
fullmodtxt is offline   Reply With Quote
Old 04-13-2005, 04:21 AM   #17
Colt Python/SR9c
IMO, i would stay away from the savage shocks. You can get the same amount of travel out of a set of Maxx shocks if placement is right.
It's lookin good so far though
Old 04-13-2005, 07:04 AM   #18
Thanks to all for yours suggetions. Now i go to finish the frame and to find the optimal placement for Maxx Shocks!!
Old 04-16-2005, 02:13 AM   #20
Two pics of the roll cage:
http://garrett.altervista.org/magazz.../Foto(392).jpg
http://garrett.altervista.org/magazz.../Foto(393).jpg
I have used savage stock shocks
