Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: One motor in an emaxx? non-evx
Old 04-15-2005, 01:21 AM   #1
Default One motor in an emaxx? non-evx
So I searched and found the evx mod, but can you run a single motor in an emaxx that doesn't have an evx?
I'm asking because a friend offered me his emaxx for 150 bucks with a lot of extra stuff. Is that a good deal? It seems like it.
cuban b is offline   Reply With Quote
Old 04-15-2005, 01:28 AM   #2
2006 2.2 National Champ
BENDER's Avatar
You can run a single motor in an E-maxx with pretty much any speed control, most run a lathe motor or Mag Mayhem. Personally, I like 1 motor with a reduction unit like the GD-600. Depending on how you gear it a lathe with a reduction is a little on the slow side, but you get tons of torque.
If you plan on running dual servos spring for the Super Rooster.
BENDER is offline   Reply With Quote
Old 04-15-2005, 01:32 AM   #3
150$ is a great price for an emaxx, I just bought mine brand new for 300$ and like it alot
T-maxximum is offline   Reply With Quote
Old 04-15-2005, 01:57 AM   #4
So, does running one motor with the traxxas esc require the same mod as with the evx or do you just hook up one motor?
Old 04-15-2005, 02:04 AM   #5
BENDER's Avatar
The EVX is wired for 2 motors. Which ESC are you asking about? You should be able to plug it in and go, if the ESC is set-up to run 1 motor.
Old 04-15-2005, 03:00 AM   #6
I'm talking about the stock traxxas esc (pre-evx emaxx). I assume it's wired for two motors. I just don't know anything about it.
Old 04-15-2005, 03:10 AM   #7
BENDER's Avatar
The original ESC for the E-maxx, the VX12? They re-called those, why does he still have it? It is wired for 2 motors.
Old 04-15-2005, 03:56 AM   #8
I'm only assuming that's what it is because I know it is an older emaxx. If it was recalled, it may not be. I'll be getting the truck next week, so I'll have to figure it out for sure then. Thanks for your help, I'm kind of getting an idea of where to go with this now.
Old 04-15-2005, 02:43 PM   #9
Colt Python/SR9c
TwistedCreations's Avatar
didnt read the whole post, but i HIGHLY suggest you dont try and run one motor and one batery with that TItan motor. the Titan motor is intended for 14.4 volts. feeding it only 7.2 volts will cuase it to only run at half speed
TwistedCreations is offline   Reply With Quote
Old 04-15-2005, 03:09 PM   #10
what ever you do, dont use titans, they are not cool.
Magic is offline   Reply With Quote
