Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: 4ws
Old 02-22-2004, 08:10 PM   #1
Default 4ws
Does anyone here know how to do it without buying the 100 dollar kit? Maybe if someone had there own kit that they built that they could make me one and sell it for cheaper.
MaxxZilla is offline   Reply With Quote
Old 02-22-2004, 08:39 PM   #2
Default Re: 4ws
I know that some of the guys on the Traxxas site have done it. I beleive they used all stock parts.
Try searching http://monster.traxxas.com/index.php...e9e45f061f589a
mascman is offline   Reply With Quote
Old 02-22-2004, 08:52 PM   #3
Default Re: 4ws
I can't do much on that site except look. I've been banned for no reason.
Old 03-04-2004, 12:42 AM   #4
Default Re: 4ws
Hi Maxx,,,
I just finished a 4 wheel steer E-Maxx.... Works quite well... I'll have some pics out here tomorrow or the next day... It's built with all stock parts off the wall,,, except ,,, the chassis,,, I built it from 1/8th inch aluminum plate... It's 2 inches longer than stock.. It took me two evenings and my trusty jig saw with a metal cutting blade in it .. Anyway,, I'll have pics in the next couple days...
cya bud,,, , Chuck
CHSRacing is offline   Reply With Quote
Old 03-04-2004, 02:03 AM   #5
Default Re: 4ws
Thanks, any info will be a help.
Old 03-04-2004, 06:24 AM   #6
Colt Python/SR9c
TwistedCreations's Avatar
Default Re: 4ws
where is the $100 kit at Zilla? i haven't seen it
also( sorry to hijack) but when using the stock TQ3 radio,is there anyway to have the steering independant or do you have to go out and just buy a Y connector and have the wheels turn together?
nevermind, i seen over at rcrad they had a kit
jeremy
TwistedCreations is offline   Reply With Quote
Old 03-05-2004, 10:50 AM   #7
Default Re: 4ws
I just finished up the rear steer on my E Maxx.I will take a couple pics when I get home.I made a servo bracket that mounts the servo in the same position as the Rad RC kit.It works great but,my only problem is the rear servo is turning the same direction as the front.Switching wires around at the rear servo does not reverse operation as I was shown in my searches.
Anyone know how to switch servo rotation without the Rad RC harness?
Chris
FRIZZLEFRY is offline   Reply With Quote
Old 03-05-2004, 02:06 PM   #8
Default Re: 4ws
i have done 4ws on a few maxxs and i like the one the guy made on www.rcrock.com he used stock part from the bellcranks and attached them to the front of the bulkhead it is pritty easy and looks sweet.
skyjacker_rc_club is offline   Reply With Quote
Old 03-07-2004, 08:52 AM   #9
Guest
Posts: n/a
Default Re: 4ws
Here is a couple pics of mine.I got it workin right with a reverser harness I found local.It is sooooo nice having rear steer
Click the image to open in full size.[/img]
Old 03-07-2004, 12:50 PM   #10
Default Re: 4ws
Here is another shot of it.The servo I used is a Futaba unit.
Its at least 12+ years old and it works better than the front one.
Old 03-07-2004, 05:09 PM   #11
Colt Python/SR9c
Default Re: 4ws
are those the only pics of it you have? i really cant see the bracket itsself to good..where is it actually mounted? looks good
btw- did ya make the cage? thats about the look im wanting to do with mine for now and still have it use the stock body mounts..looks great
Old 03-07-2004, 07:38 PM   #12
The Wheels Keep Turning
kevinlongisland's Avatar
Default Re: 4ws
i also setup a 4ws that seems to be similiar to this one:
but i have problems with the tires pointing in different directions when they are at different points of the vertical wheel travel. it's mostly a problem with the height of the attachment points, to low. it looks like rcrocks is at the same spot as mine, probably has the same problems.
i have also setup steering like this:
the wheels keep better alignment with this method. i'd be interested in seeing some other 4ws setup for the max though. i haven't been fully satisfied with either of these setups. also, does anyone have the link to the place that makes the $100 steering kit?????
kevinlongisland is offline   Reply With Quote
Old 03-07-2004, 07:43 PM   #13
Colt Python/SR9c
Default Re: 4ws
here kevin,
www.radrc.com
Old 03-07-2004, 07:54 PM   #14
Default Re: 4ws
thank you, looks like you could buy the spare parts kit for $40 and be most of the way complete except for links. and you can use widemaxx links on a non widemaxx truck for this type of steering setup, thats what i have on mine
Old 03-08-2004, 07:37 AM   #15
Default Re: 4ws
Here is another pic.The servo was mounted much lower and it was causing steering problems when cycling the suspension.I raised it up so that the tierods are paralell to the arms to fix it.
Old 03-08-2004, 07:58 PM   #16
Colt Python/SR9c
Default Re: 4ws
cool deal frizzle,thanks for the pic.. i got the template done for the bracket and will cut it out tomorrow,but still trying to figure out what to use for the other part of it( the part that the servo screws to) did you just use a square piece of plastic or something and have it screwed to the bracket then?
i thought about just using some metal and just tack welding on those pieces,but i would like to keep it somewhat adjustable if i need it to be..
Thanks again for the pic
Old 03-08-2004, 08:58 PM   #17
Default Re: 4ws
They are just square pieces of plastic from the steering servo mount off of my old Grasshopper 2.Using metal and welding them to the bracket would be cool.Just make sure the steering links are paralell to the arms (when looking at them from the rear) to get the best steering opperation through out the wheel travel Leaving it adjustable is good.I drilled quite a few holes moving stuff around to get things just right.
Chris
Old 03-08-2004, 10:15 PM   #18
Default Re: 4ws
are any of you guys running spools in the rear with rear steer?? i break enough rear end parts as it is without rear steer. i would think it would put a lot more stress on it.
zeus is offline   Reply With Quote
Old 03-09-2004, 05:33 AM   #19
Colt Python/SR9c
Default Re: 4ws
well thats like the hardcore guys running with the front locked also..anytime you lock something, it will add to the stress.i haven't broke anything while "crawling" with a spool in the rear,but as soon as i hit the throttle and floor it to climb a hill(run around like a nut) "snap" i done broke something
that's why you put air lockers in it,so you can turn them on and off when ya want
thanks for the help and advice frizzle,much appreciated
Old 03-09-2004, 09:37 AM   #20
Default Re: 4ws
I have a spool and CV shafts in the rear.The only thing I have broken out back since upgrading the shafts are the 4 screws that hold the gear to the spool.They just sorta sheered off No damage though,I just replaced them and I was back in business.
Hmmm....an ARB for RC trucks.That would be sweet!Run it off of a CO2 cartridge from a pellet gun
Post up some pics when yer done Toyotafourwheeln
