| | #1 |
| Guest
Posts: n/a
| Hey i got a question i had these batterypack sittin for like a year and they wouldent charge but then after pushin the charge button several times they charged so i was like ok and i put em in my maxx they ran fine but kinda slo the motors did'nt get hot or nething then i went to charge em back up na di put em in my car and nothing..... it stears the shifting servo worksa the light changes but it's like no power is goin to the motors is the evx fried and if it is, is it because of the batteries? |
| Sponsored Links | |
| | #2 |
| Guest
Posts: n/a
| wat nobody's gonna answer i need to know if my batts caused it b4 i get a new evx so it doesent happen again! |
| | #3 |
| The Wheels Keep Turning ![]() Join Date: Jan 2004 Location: Phoenix, Arizona
| that could definitely be your batteries. try out some good batteries. |
| | #4 |
| Newbie Join Date: Jun 2004
| yeah sounds like your batts are done for. even if they ARE charging they may not be holding the charge, or discharging at some insane voltage. id think they could hurt the ESC, so i would just get new batts. |
| | #5 |
| Guest
Posts: n/a
| well i sent my EVX in and im gonna prolly get some new batts so woopie? |
| | #6 |
| Guest
Posts: n/a
| let me know what they say, i have nearly the same prob just i have new 3300 matched packs and it worked fine then it quit working so i resoldered the batts charge and installed them the light comes the servo turs but it wont move dont know how to check the esc but it or the motors are burned the motors got hot when i drove it but not the esc thanks donald elam |
| | #7 |
| Pebble Pounder ![]() Join Date: Jul 2004 Location: Quakertown PA
| My Maxx just did the same thing. Was running fine but the motors got so hot the little fan blades inside one of them started to turn black and melt. Now it does what you are saying. My steering wouldnt hardly turn though either. Swapped the receiver with my savage one to rule out that. Steering servo worked fine but the light on the speed control went out when you turned the steering. Still no change in throttle. I KNOW my batts are fine. So pretty much tells me the EVX went bad some how. Popped the case open but didnt see anything major. Of course one tiny component being bad and the thing dont work. Has anyone heard of problems with these EVX's? Dont know if I want to send it back since its out of warranty or buy something to replace it. Eric |
| | #8 |
| mine did the same thing right after i ran it threw the snow thought i got it seald up good but nope. it took me a month to get a new one but the damn thing didint work so it tooke 2 months and 2 evx's john |
| | #9 |
| I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Here is everything you need to know about EVX's They are awesome, if you aren't an idiot, they are even more awesome. I was an idiot and friend mine. The twitchiness is caused my internal resistance. Fix this by: Hardwiring your motors (No more connectors, so much voltage, not enough connector) Replace the battery plugs, the stock ones suck. Get Deans. Rip off the power plug and solder the two wires together, that is a BIG cause of problems, it arcs and stuff all the time. Make sure you have good radio batteries, its sensitive. Run a reciever battery, I did that and it helped with the twichiness. Lastly: THEY DONT LIKE WATER, YOU KNOW THIS, STOP RUNNING IT IN WATER Now everything you need to know about the Titans. THEY SUCK BALLS. They are VERY poorly made. They also have no oomph. The fans inside them melt, then the brushes break off, and they aren't user servicable. Get 540's, get two good 540 motors (Ones that can handle 14V or ones that can't if you dont care... Like me) And running 540's doesn't void your warranty, I talked to the guys at Traxxas (AWESOME bunch, I love em) and all he said was "We won't reccomend it." me: So it doesn't void the warranty? "Well... We don't reccomend it" me: So If it fries I can still send it in "So anyway, you run the EVX on a clod?" |
| | #10 |
| Rock Crawler Join Date: Apr 2004 Location: North GA
| My EVX fried 7 times. 2 Words: NO WATER |
| | #11 |
| Ok Dave, I'll try the hard wiring and see what happens. Eric |
| | #12 | |
| | #13 |
| Guest
Posts: n/a
| my evx has never been near water its out of warranty but i talked to traxxas and they said to send it and 20 dollars and they would fix it my problem is i am not sure its the esc but i dont know how to check it or the motors i cant see any visible damage and there is no sighns of it not working(exept the motors dont turn over)does anyone have experince with the trinnity motors or another 550 motors that will work and are cheap because i have tomany projects right now to spend alot on the maxx |
| | #14 | |
| Thread Tools | |
| Display Modes | |
