Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: Maxx Crawler started
Old 05-10-2005, 04:19 PM   #1
Talking Maxx Crawler started
Ok, it got started a while ago, but I'm getting somewhere now
First draft of the chassis had the gearbox poking thru the bottom, with a second sub chassis wrapped around it!
New version has the gearbox 'up on blocks' - Saves making the sub chassis - dunno what I was on that night!
On the output shaft is another 'anti'torque' transfer box, like I made for the TLT - no body roll on this one neither (I hope)
Final layout for the chassis tub - before bending.
Spoke to the guy making it today, and it's already in the post
Anti-Torque tansfer box front plates and housing
Diff Housing, with groove for UJ screw access
Many thanks to Rich Morrison for his help thus far - Cheers muchly Chap
TWINSET is offline   Reply With Quote
Old 05-10-2005, 05:01 PM   #2
Wink
Looking good as usual Andy
MadMax is offline   Reply With Quote
Old 05-10-2005, 09:09 PM   #3
YW for any help I might have given, but honestly, I've NEVER created anything high quality like that for myself yet.......YET!
Looks awesome man, keep us posted!
WRMorrison is offline   Reply With Quote
Old 05-10-2005, 09:13 PM   #4
w - o - w .....................ok i got my 2 cents in !
Eclipse is offline   Reply With Quote
Old 05-11-2005, 01:03 PM   #5
Great start! If you keep the entire rig as high quality as you have with the first couple parts, your going have one kickass rig. Keep posting those pics.
jonnycat01 is offline   Reply With Quote
Old 05-26-2005, 01:53 PM   #6
Getting some bits back from the plaaters now;
Diff mounts
Top hole at the rear has a 4mm pem nut pressed in, for mounting top links
Steering blocks
Made of steel, bit of strength, bit of weight
Plated black zinc
Transfer case
Case and bearing housings, hard anodized 7075 alu
Gears, black zinc'd steel
Old 05-26-2005, 02:25 PM   #7
did you make those peices your self ?
crunk crawlin is offline   Reply With Quote
Old 05-26-2005, 03:01 PM   #8
No chap, just drew them.
I'm a buyer for an engineering company, so deal with a lot of machine shops
Old 05-27-2005, 10:43 AM   #9
im digging that transfer case. Will you be able to use diferent ratio's with different gear sets or will only one specifit set fit?
lodikrawlingkiller is offline   Reply With Quote
Old 05-27-2005, 10:45 AM   #10
The transfer case is solely to drive the rear axle, so the ratio needs to be the same as the front.
I'm using a standard Maxx gearbox as primary.
Old 05-27-2005, 10:59 AM   #11
looks awsome i know i would want that anti-torqe transfer case on my maxx keep up the good dealing
matt
crawler is offline   Reply With Quote
Old 05-29-2005, 09:07 PM   #12
I think he might have meant a different ratio for the axles. like how clods do the 9t rear and 10t front.
RCMFMaxxMan is offline   Reply With Quote
Old 05-30-2005, 05:17 AM   #13
Ah ok, no, it's a 1:1 transfer
I guess you could make it adjustable, but the axle centres for the bearings would make it a bit difficult.
Thinking about it, would there be a need for two different ratios, if it's shaft drive?
Old 06-09-2005, 01:13 PM   #14
Got bits flowing in thick and fast now!
Still waiting for gearbox mounts and gearbox-transfer case shafts, but it's starting to resemble something (dunno what though)
Transfer case in situ (toward rear)
Offset gearbox, so both shafts are symmetrically offset front and rear.
Room on right for batteries
Countersunk fixing holes
View from the front - top arms being remade due to drawing carve-up
Diff blocks with grub screw access slot
Thru the top arm, bottom ones left solid
18" Wheelbase mock-up
Top arm was going to have servo mounted on it, but it looked too tall, so shelved that idea.
Pem nut in diff block is possible link mounting point, but unlikely now.
Old 06-09-2005, 02:08 PM   #15
damn dude that thing is HD. and as for my earlier post about the transfer case. I didnt read the earlier post and though it was like a true granny box or somthing like a gear reduction unit sorry for the confussion.
Old 06-09-2005, 02:11 PM   #16
..........earlier post about the transfer case. I didnt read the earlier post and though it was like a true granny box or somthing like a gear reduction unit sorry for the confussion.
No worries, thought I missed something critical - one ounce of doubt and it's all in the bin and start again
Link placement next, that sholud be fun!
Old 06-09-2005, 05:20 PM   #17
looks good.
mike is offline   Reply With Quote
Old 06-09-2005, 11:47 PM   #18
i....want....one....too...!
Old 06-14-2005, 08:02 AM   #19
Default Quick steering question
This project is starting to come together now, but one question;
For rear steering, should the steering rods be in front or behind the axles?
From a protection point of view, I guess behind would be better, but does it have any negative aspects?
Old 06-14-2005, 01:32 PM   #20
behind the rear axle. no negative aspects. It works exactly the same as if you were to mount in front of it except it doesn't get bashed so much.
