Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Traxxas Maxx Crawlers
Thread: finally ran it..tranny/takeoff questions(newbie)
Old 02-24-2004, 09:52 PM   #1
Colt Python/SR9c
TwistedCreations's Avatar
Default finally ran it..tranny/takeoff questions(newbie)
well since trading my Tmaxx for an Emaxx,i have been waiting to get the ESC back from Traxxas( which the previous owner paid for) well i finally have ran it today and man this thing has alot or torque
but on other Emaxxs in 1st gear ( stock) can you guys floor it from a start and stand it up? mine will not stand up at all..the thing flies,but just the standing start seems funny..also when i floor it,it sounds like gears are spinning at first,is this normal? ( just seems loud) ...just kinda seems like its slipping as it takes off,then as it goes a few feet,then its like someone hit the nitrous. any ideas?
also, what is the purpose of the slipper clutch? that is the gear w/ the spring and nut holding it on thats between the motors right? or am i just way off
thanks for the newbie help
Jeremy
TwistedCreations is offline   Reply With Quote
Old 02-25-2004, 08:19 AM   #2
Guest
Posts: n/a
Default Re: finally ran it..tranny/takeoff questions(newbie)
Tighten up your slipper clutch, that noise you hear may be your clutch set to loose. Try to tighten it and your maxx should flip over backwards!
Old 02-25-2004, 09:40 AM   #3
Colt Python/SR9c
WOW!!! 8O 8O that makes a HUGE difference
thanks for the help nitro,maybe i want it to slip just a bit( not as much as it did though). if not i may be walking over and flipping it back over all the time
thanks again
