03-16-2014, 10:24 PM | #1 |
Rock Crawler Join Date: Mar 2014 Location: Yorkville
Well New to the fourm but heres my giant summit. rc4wd Superswampers on custom rims and some rpm arms and blue alum to stiffen the chassis up it turend out to be a fun vehicle. cant figure out images on this site so here check it out on clodtalk. ClodTalk.com - View topic - Project Summit Overkill. http://www.clodtalk.com/download/file.php?id=32483 http://www.clodtalk.com/download/file.php?id=32482 there i figured it out kinda. Last edited by THX_138; 03-28-2014 at 12:45 AM. |
03-17-2014, 08:49 AM | #2 |
Pebble Pounder Join Date: Jan 2013 Location: Bc
| Re: Summit overkill
similar project here as well Huge Traxxas Summit OVERKILL |
03-17-2014, 06:39 PM | #3 |
sept mine is 90% stock and actually practical. just saying, its a cool build but definitely not for your everyday drivers, its way to much work. and mine is meant to put the rc4wd super swampers on the map for a normal vehicle and showing that you can run them on a normal 4s system and stock chassis and motors/ standard BL not a 400 system... also i went for speed and agility, he made a crawler. there just 100% different except the tires. also im sure he has a whole stock pile of diffs cause even with those aluminum cups if he locks the diffs hes going to brak the screws off that hold the ring on, ive done it with the summit on 4s with trencher x's on it. however GL to him on that part i actually run a stock diff in the front still, haven't had problems with it. Last edited by THX_138; 03-28-2014 at 12:46 AM. |
03-20-2014, 09:52 PM | #4 | |
Newbie Join Date: Mar 2014 Location: Maysville
| Re: Summit overkill Quote:
03-21-2014, 05:59 PM | #5 | |
04-05-2014, 05:03 PM | #6 |
| Re: Summit overkill
will be upgrading my Diffs tonight, finally broke my rear one and am going to put on an aluminum cup to solve my issues.
04-06-2014, 09:45 AM | #7 |
| Re: Summit overkill
got the summit out for some fun in the mud, went places none of my other rigs can go thats a defined difference with the tires
04-08-2014, 06:56 PM | #8 |
| Re: Summit overkill
well went to the park behind my house with a couple buddys and while i was giving them a power display of the summit i heard the infamous click of teeth broken off the ring gear, so the diff holds up now its just the ring and/or pinion giving me trouble maby i can find harder diff ring.
04-11-2014, 09:35 AM | #9 |
| Re: Summit overkill
have you shimmed your diff and pinion?
04-11-2014, 10:16 AM | #10 |
Quarry Creeper Join Date: Jan 2009 Location: Victoira,BC
| Re: Summit overkill
sounds like it breaks everytime you go out, that sounds like fun
04-11-2014, 10:33 AM | #11 |
Quarry Creeper Join Date: Dec 2012 Location: Seattle
04-11-2014, 06:59 PM | #12 |
| Re: Summit overkill
i replaced the diffs and there fine now, ive run it multiple times and no breakage, and im not going easy on it. also i have shimmed them and its much better, and its far from breaking something every time i go out, i have driven this truck alot more than i post about it. i just post when shit breaks.
04-19-2014, 10:26 PM | #13 |
| Re: Summit overkill
Gonna change out the 2050kv monstor motor and put in a tekin t8 2650 kv nd see if thats a little better for the top end since i dont need this monsters torque with the two speed tranny. |
04-27-2014, 08:35 AM | #14 |
| Re: Summit overkill
really put it through hell on rocks and mud this weekend and only thing that happened was i stretched the drive shaft, the rear center, it didn't break but stretched at the yolks, so i threw in a steel dog bone i had from my stretched emaxx that fit like a charm and i know will never break. shimmed my front and rear diff a little tighter today too and now there perfect, now to just figure a better suspension set up, fronts too mushy and rear is too stiff,
04-27-2014, 04:19 PM | #15 |
| Re: Summit overkill
Mudding with the summit,
07-26-2014, 10:09 AM | #16 |
| Re: Summit overkill
thanks! its lots of fun, i have been running the hell out of it lately since we have been having good weather in Illinois,
07-27-2014, 12:52 PM | #17 |
Quarry Creeper Join Date: Jul 2010 Location: My garage...
| Re: Summit overkill
Have to get together and run sometime. I'm about 20 min. From Yorkville.
07-27-2014, 03:43 PM | #18 |
| Re: Summit overkill
yeah i have a whole fleet i normally take out, id love to find some people in the area to go do somethin with
Summit overkill - Similar Threads | ||||
Overkill or not? | Verdion | Formula Offroad | 21 | 01-27-2013 04:57 AM |
overkill too overkill? | losikid | Chit Chat | 2 | 05-16-2011 08:47 AM |
Overkill? | Cob | Newbie General | 3 | 06-27-2008 10:09 AM |
is this overkill? | STEEL_CITY_CRAWLER | Electronics | 1 | 04-03-2007 10:21 AM |
Overkill servo? | onefstsnake | Electronics | 11 | 07-05-2006 07:28 PM |
