04-22-2014, 08:55 PM | #1 |
Newbie Join Date: Apr 2014 Location: canada
| Traxxas Summit Problem HELP!
hi, their im having some troubles with my truck it's not driving in high gear and it wont shift no matter what please comment back if you have any ideas I'm trying to post a video of it.
04-22-2014, 09:31 PM | #2 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
So it won't shift if you move the shift rod into second gear by hand?
04-22-2014, 10:35 PM | #3 |
| Re: Traxxas Summit Problem HELP!
Yea i tried it by hand but it didn't budge one bit do you have a solution ?
04-22-2014, 10:41 PM | #4 |
If the shift rod is absolutley stuck then I'd say you have to pull the trans and carefully take it apart. Never heard of this problem. If its that bad then the problem will be very obvious when it's pulled apart. Usually it's just a stock servo that's stripped and won't turn. I know there's a ball and spring that seats into the shift shaft in a groove. To ease shifting in mine I removed a couple loops of the spring. Be careful not to lose anything in the process and to put it back together right.
04-22-2014, 10:47 PM | #5 |
I've got the transmission pulled and I'm looking at the gears inside what should I be looking for. Also before I took apart the tranny I did lose off the ball and spring inside the tranny, how tight should you make the grub screw that holds the ball and spring ? I also know that my servo isn't stripped noir binding with anything.
04-22-2014, 10:50 PM | #6 |
It's really been at least a year and a half since I did this. But I'd say just loosen the. Grub and keep moving the shaft between gears until it lightly locks and easily disengages by hand. The stock shift servo is pretty light duty. Once it's in gear by the servo it's pretty secure until you shift.
04-22-2014, 10:56 PM | #7 |
I got the truck used could it be that the previous owner took apart the tranny and ****** something up? Is their a video on how to disassemble and tranny?
04-22-2014, 11:09 PM | #8 |
Search YouTube and google search for a how to. That's how I got it. http://youtu.be/3tqPVSB6dtA Last edited by CrawlinMike; 04-22-2014 at 11:12 PM. |
05-04-2014, 03:26 PM | #9 |
Newbie Join Date: Dec 2013 Location: roseburg
You can find great vids on you tube
05-08-2014, 12:40 PM | #10 |
Newbie Join Date: May 2014 Location: Ledyard
Mine i blew the gear that the adjuster connects to.. So it wouldnt click into 2nd.
Traxxas Summit Problem HELP! - Similar Threads | ||||
new 1/16 summit problem? | Gravebane525 | Traxxas Crawlers | 5 | 10-13-2013 09:23 PM |
Reverse problem with the summit | durwank | Traxxas Crawlers | 14 | 09-18-2011 12:20 AM |
Strange Summit problem | durwank | Traxxas Crawlers | 4 | 10-20-2010 10:01 PM |
summit problem | heminutt | Traxxas Crawlers | 9 | 09-13-2009 08:53 PM |
Summit front diff servo problem | Tonelock | General Crawlers | 5 | 03-21-2009 09:05 PM |
