07-02-2014, 08:39 PM | #1 |
Newbie Join Date: Aug 2013 Location: canada
| summit lt build issues
got the slayer pro arms and suspension on, went with some lighter springs. problem is when I flex suspension front and rear the tires will angel instead of staying parallel with the frame. has me stumped what am I missing
07-03-2014, 09:23 AM | #2 |
Rock Crawler Join Date: Oct 2007 Location: south of France
| Re: summit lt build issues
look at the rod end set up on the wheel side, it can make this happen
07-03-2014, 11:45 AM | #3 |
Angle how? Towards the top or towards the front? To the top: The chassis has 2 mounts for the inner hing pin on the upper arms. Most likely it is in the lower mount which gives more camber as suspension compresses. Try moving it to the top mount. To the front: Classic bump steer. Steering links have to be parallel to the suspension arms and the same lengths as much as possible. Assuming they are not parallel - The revo/summit/slayer platform uses adjustable ball ends that can make some adjustments. Refer to the reactive tow/bump steer chart about 3/4 of the way down the page - should help you get it dialed in: Traxxas - Revo Performance Set-Up Guide (Part 1) | traxxas.com in fact, the camber section is right below it too - worth a read. |
07-03-2014, 07:44 PM | #4 |
looking from on top when suspension is pushed down the rear tires will angle in getting closer to bumper if that makes sense
07-23-2014, 04:25 AM | #5 |
Newbie Join Date: Aug 2013 Location: Australia
Have you got the arms on the right sides?
summit lt build issues - Similar Threads | ||||
Summit diff issues? | jaymann | Traxxas Crawlers | 21 | 10-26-2013 11:42 PM |
summit trans class 3 build | scrap value | 2.2 Scale Rigs | 2 | 09-15-2011 12:24 AM |
New Creeper build issues - Not very good QC at Venom... | rwkhaussupply | Venom Creeper | 15 | 01-19-2010 06:56 AM |
issues with rear axle build | slegh | Tamiya TLT Crawlers | 6 | 06-02-2008 08:57 AM |
Need some help - build problems/issues. | Nerve | HPI Wheely King | 25 | 11-15-2007 09:09 PM |
