08-21-2014, 07:35 AM | #1 |
Newbie Join Date: Aug 2014 Location: cn
| new Summit reverse problem
I am a rc car beginner, I got a new Summit today (well, claimed by the LHS it's new, but more like display model or older model, since the model number is 5607, not the latest 56076 listed on official Traxxas website). Anyway, it seems has some problem and I'd like to find out how I can fix it. It drives forward, no problem, release the throttle, brakes and stop, no problem, immediately after sit fully stops, throttle reverse, it will not move. Release throttle, reverse again and release; it will go reversed after 2nd or even 3rd try. Why is this? Thanks for you help. |
09-12-2014, 06:48 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: Jonesboro, TN
| Re: new Summit reverse problem
That is normal. If you pull the trigger to move forward, then push trigger the first push is the brakes. Then after it stops, the next push of the trigger is reverse. That's a safety feature to protect the transmission. Normal RC car ESC's are forward/brake/reverse but you can get rock crawler specific ESC's that are forward/reverse only, no brake. They are useful in crawling on steep uphill sections so you can quickly hit reverse and save your rig from flipping over backwards
10-26-2014, 10:23 AM | #3 |
Rock Stacker Join Date: Dec 2011 Location: Coaldale
I thought the same think when I got mine until I read about it. the guy at hobbytown did not even know that
10-27-2014, 06:04 PM | #4 |
Pebble Pounder Join Date: Jun 2007 Location: My House
You might try to recalibrate. As was said before, the speed control brakes first, then will reverse after you let off the brakes. If the calibration is off a little, it might not be seeing the brake fully released before you try to reverse.
new Summit reverse problem - Similar Threads | ||||
AX10 reverse problem. | Mr.JayDeeM | Axial AX-10 Scorpion | 10 | 10-31-2011 07:24 PM |
Reverse problem with the summit | durwank | Traxxas Crawlers | 14 | 09-18-2011 12:20 AM |
Reverse problem | calikingcrawler | Axial AX-10 Scorpion | 3 | 03-14-2009 04:28 PM |
reverse problem | mudrinner4ever | General Crawlers | 2 | 06-24-2006 12:41 PM |
