![]() | #101 |
Rock Stacker Join Date: Sep 2017 Location: in a RV
| ![]() I have the proline faultline wheels and the inner beadlock ring needs to be enlarged to gain clearance to the portal covers. Also I installed MIP 4mm axle extensions for additional clearance.
![]() | #102 |
Newbie Join Date: Nov 2017 Location: Tonawanda
so with the rc4wd hex adapters i used the wheels fit but when i tighten the nut down its bottoms out on the threads and the wheels are a little loose. Like a couple thousandths of an inch of movement at most probably but its there.....do I run a washer behind the nut?! Do i need wider hexes? I didn't see anyone mention this particular issue with the rc4wd steel wagon wheels.
![]() | #103 |
Newbie Join Date: Jul 2017 Location: New Philadelphia
I didn’t have that issue with mine but I would say a washer behind the nut would be a cheap easy fix Sent from my iPhone using Tapatalk |
![]() | #104 |
I noticed when I took the pin drive adapter off to put the hex adapter on that the hex one is narrower than the pin drive.....when i put the wheels on and look at it you can see the end of the threads are right at the face of the wheel
![]() | #105 | |
Quarry Creeper Join Date: Dec 2016 Location: westlerly
| ![]() Quote:
Sent from my SAMSUNG-SM-G920A using Tapatalk | |
![]() | #106 |
I ended up replacing the stock Traxxas wheel hexes with rc4wd part #Z-S1844 and everything is perfect now. I was under the assumption that I could just change from pin drive to hex drive on the back of the wheel and use the stock hexes but they were too narrow
![]() | #107 |
![]() | #108 |
That’s all I had to do was get the adapters for the back of the wheel Sent from my iPhone using Tapatalk |
![]() | #109 |
with rc4wd wagon wheels? look very closely at the wheel face around the nut...wiggle it slowly and look closely....it very well may be loose and maybe you didn't notice....it's a very minute amount of looseness....probably a couple thousandths of an inch of movement or so but it's there and I can't imagine I'm the only one......unless I got something that was machined improperly or something strange like that....
![]() | #110 |
also, I did not have to drill out the center hole at all for the wheel to fit on all the way like a few other people said they had to so there's that too.......
![]() | #111 |
Pebble Pounder Join Date: Dec 2005 Location: lawrenceburg
What width slw hubs with vanquish wheels Is closest to stock? Last edited by treadway47025; 03-16-2018 at 07:14 PM. Reason: Typo |
![]() | #112 |
Newbie Join Date: Aug 2016 Location: USA
These should fit, right? 46.5 mm inner diameter in the back, and they show it fitting the Wraith. https://store.rc4wd.com/Rally-19-Bea...ls_p_5691.html |
![]() | #113 |
Should be no problems. Looks like they'll clear the portals and the hex is fine.
![]() | #114 |
Rock Stacker Join Date: May 2018 Location: North Carolina
MOHERO Silver wheels https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1 DO NOT fit TRX-4 stock. Pretty serious rub on both front and back. Some brass Treal +3mm hexes were perfect. Stance is very sexy, just a hair wider than the stock tires sat. Editting in some nonsense so googlers might stumble across this post: Amazon cheap mohero trx-4 trx4 mohero wheels traxxas wheel fitment mohero fitment Mohero wheels fitting trx-4 do mohero wheels fit traxxas? |
![]() | #115 |
Also, I have gone through this thread pretty carefully and haven't seen this chart posted yet. i found it on RC4WD and it seems like an excellent quick reference for wheel specs: https://www.beadlok.com/wheel.pdf |
![]() | #116 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
Anyone know if these will clear the portals and some CODYBOY wheel weights? Really like the look of them. https://m.ebay.com/itm/1-9-Beadlock-...from=R40&rt=nc |
![]() | #117 | |
I wanna be Dave ![]() Join Date: Apr 2010 Location: Oakridge
| ![]() Quote:
Hey Justin, I would be careful buying any wheel with a rear beadlock ring. I know some of them out there with the rear ring will not fit over the portals. It's hard to tell by looking at the photos. ![]() Ernie | |
![]() | #118 |
Thank you brotha!
![]() | #119 |
Rock Stacker Join Date: Aug 2005 Location: Spain
Gmade MT1904 1.9 tires on INJORA beadlock (4PCS RC Rock Crawler Metal Wheel Rim for 1/10 ) https://www.aliexpress.com/wholesale...njora+beadlock ![]() They fit perfectly and the bead locks are easy to assemble. Measures 121 * 45 mm You just have to widen the outer hole rim 1 mm, from 5mm to 6mm Tires Gmade MT1904 1.9 ![]() |
![]() | #120 |
Newbie Join Date: Aug 2018 Location: UK
Without reading through stuff I honestly do not understand. I am a tad more confused now. Is there a definitive list of direct fits? Maybe a list which requires a hub add on. I am after some direct fit 2.2 wheels and tyres that I can buy without going too wrong. I do not run a body so no rubbing issues. |
Stock tire wheel fitment | racer | Vaterra Ascender | 4 | 08-17-2016 10:18 AM |
DLUX Front End Guide and Wheel Fitment | 802coma | Axial Yeti | 46 | 04-10-2016 10:18 AM |
2014 Focus wheel fitment | Elmo | 1:1 Full Size Vehicles | 5 | 07-23-2015 02:30 PM |
Newbie Tire Question - Moab XL Wheel Fitment | Spark Plug | Tires and Wheels | 4 | 10-24-2009 04:33 PM |
RC4WD steel wheel fitment? | theslowguy | Tires and Wheels | 4 | 09-17-2009 05:00 AM |
