Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: TRX4 wheel fitment info
Old 08-31-2018, 09:29 AM   #121
cartronicshn's Avatar
Default Re: TRX4 wheel fitment info
not sure if they have been posted, redcats 1.9 beadlocks fit on the trx4, i bought a set of wheels and tires mounted (tires work really well) and are a really cheap alternative.
cartronicshn is offline   Reply With Quote
Old 09-04-2018, 06:46 PM   #122
I just put that same wheel/tire combo on my TRX4 last weekend, except mine are actual RC4WD Interco tires. Had to paint the rings to match of course.
Up'n'Over is offline   Reply With Quote
Old 09-30-2018, 12:29 AM   #123
I have come to the conclusion that the axle stub is 4mm, 5mm and 6mm. See pic for reference. I enlarged my center rim hole with a 5mm reamer and they fit great.
Amazon link to rims
https://www.amazon.com/MOHERO-Beadlo...70_&dpSrc=srch
Spryguy is offline   Reply With Quote
Old 09-30-2018, 12:38 AM   #124
I also got the mohero 1.9 wheels from amazon. Amazon link to rims
This is how they fit before the +3mm wheel hexes. They rub on the portal bolts. Might work if the bolts where flat and not cap screws. I got my Treal +3mm wheel hexes and these now fit perfect.
Don’t mind the muck on the truck. This was after a river bank run session and before tear down for cleanup.
Old 09-30-2018, 12:42 AM   #125
These cheap steel wheels fit perfect. No mods required and look good. https://www.amazon.com/gp/aw/d/B0731...o_pop_mb_pd_t2
I used these hyrax knockoffs https://www.amazon.com/gp/aw/d/B072Q...o_pop_mb_pd_t2
Look good and work good. I am running then unvented for now. Sealed up rim hole with some silicone.
Old 10-01-2018, 09:29 PM   #126
Originally Posted by Spryguy View Post
I also got the mohero 1.9 wheels from amazon. This is how they fit before the +3mm wheel hexes. They rub on the portal bolts. Might work if the bolts where flat and not cap screws.
I got a different set of Mohero 1.9 beadlock rims. They fit fantastic. I left pictures in my Amazon review to show.
MOHERO 1.9'' Alloy Beadlock 1/10 RC Wheel Rims for SCX10 CC01 RC4WD D90 TRX-4 Cars (Silver) https://www.amazon.com/dp/B0771CKQHF..._6CTSBb7V3YP3D
Sent from my Pixel 2 XL using Tapatalk
niggemannb is offline   Reply With Quote
Old 10-02-2018, 11:32 AM   #127
Hallo, does anyone know the stock TRX4 wheels' offset? Zero? I'd like to reduce the width a bit
RCPawel is offline   Reply With Quote
Old 10-02-2018, 08:46 PM   #128
Do you know if these will work with proline tires?
Sent from my SM-N950W using Tapatalk
BashNSlash is offline   Reply With Quote
Old 10-08-2018, 01:22 PM   #129
Nobody? I'd also like to know if the RC4WD Spectre rims fit or rub against the portal covers since the big inner beadlock ring, thanks.
Old 10-08-2018, 02:26 PM   #130
Thank you very much Natedog!
Old 10-10-2018, 05:37 PM   #131
Default TRX4 wheel fitment info
RC4WD 1.7" Raceline Avengers fit without any issues, stock hex.
(Not fully mounted, but as you can see: no rub)
Mud Daog is offline   Reply With Quote
Old 01-06-2019, 03:26 PM   #132
I have a question on using Gmade steel wheels. Have any of you guys used a plus 3mm hex nut? I have these lying around now. Does this leave enough axle thread? They will arrive soon and I’m exploring the option of keeping the current track width with the stock wheels. Thanks.
Verzonden vanaf mijn iPhone met Tapatalk
Landy TRX 4 is offline   Reply With Quote
Old 01-14-2019, 06:43 PM   #133
If its been answered I apologize. I went through each page. I have the RC4WD Mickey Thompsons what hex do I need to clear the portal?
HKSkook is offline   Reply With Quote
Old 02-19-2019, 01:58 PM   #134
I have this exact question right now as well so bumping this - I saw someone talking about canceling out the Gmade narrow offset with an 8mm hex to bring the truck back to 0mm offset, but in my head I can't imagine there being enough thread to bolt on the wheels. Is there enough without a long axle kit?
jessedacri is offline   Reply With Quote
Old 02-27-2019, 02:44 PM   #135
It works, I used a bit narrower Tamiya wheel nuts to make it perfect
Old 02-28-2019, 09:08 AM   #136
To use +3mm(8mm) hexes you need to have bronco stub axles with longer thread , I have some pics and info here SSD - 2 New 1.9" Chrome Steel Wheel Options - Old School!
Marek_k is offline   Reply With Quote
Old 05-12-2019, 11:11 PM   #137
Just installed RC4WD M/T Classics on Blazer. Had to take the portal covers off and Dremel them down. Cut it down until I saw a spec of bearing. Not even concerned about this. Also had to drill the hubs out on the wheels too. Overall looks and works great. Even welded up a spare tire mount that goes in the receiver hitch.
BirdDogg is offline   Reply With Quote
Old 05-23-2019, 12:48 AM   #138
I can also confirm that 1.9 Axial 8 hole beadlocks clear and will work just fine.
xtreme4x2 is offline   Reply With Quote
Old 09-22-2019, 09:01 PM   #139
Can anyone give me a minimum inner diamter which will work? Wheels I have 3d printed have a inner diamater of 36mm and I want to use them on a build with a TRX4 rear axle.
nedmo is offline   Reply With Quote
Old 09-23-2019, 02:17 PM   #140
My Gear Head wheels are 37.75-mm inside the beadlock rings and I had to file the tops of the portal covers just a little for clearance.
Hope that helps.
jim
dr frankenstyle is offline   Reply With Quote
TRX4 wheel fitment info - Similar Threads
Stock tire wheel fitment racer Vaterra Ascender 4 08-17-2016 11:18 AM
DLUX Front End Guide and Wheel Fitment 802coma Axial Yeti 46 04-10-2016 11:18 AM
2014 Focus wheel fitment Elmo 1:1 Full Size Vehicles 5 07-23-2015 03:30 PM
Newbie Tire Question - Moab XL Wheel Fitment Spark Plug Tires and Wheels 4 10-24-2009 05:33 PM
RC4WD steel wheel fitment? theslowguy Tires and Wheels 4 09-17-2009 06:00 AM
