Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: what other bodies have you guys been running?
Old 06-19-2017, 08:18 PM   #21
KMS
KMS's Avatar
Default Re: what other bodies have you guys been running?
Originally Posted by dittohead View Post
Just got a trx4 last night so naturally I had to see what other bodies fit. The proline 66f100 intended for a tmaxx fits nicely other then I need to make new rear links to get it out to 13" where I like my wb to be. I'm liking that proline hilux body i may get one of those as well
Some pics of body posts would be appreciated,, Thank you
KMS is offline   Reply With Quote
Old 06-20-2017, 04:56 AM   #22
definitely the first time i've heard anyone say they want the thing longer.. lol
good to know tmaxx bodies are a good fit tho. the more options the merrier.
ubernewb is offline   Reply With Quote
Old 06-20-2017, 08:21 AM   #23
I run most of my crawlers at 13" wb or real close to that. I like to do big climbs and the longer wb is needed.
dittohead is offline   Reply With Quote
Old 06-20-2017, 09:00 AM   #24
Default what other bodies have you guys been running?
I'm not sure what chassis you have . But I tried this proline 72 body on my Ascender . It works for me , very little trimming . Mainly around the wheels . I still want to lower the shocks but just haven't made time to do so .
F150indy is offline   Reply With Quote
Old 06-20-2017, 10:28 AM   #25
Originally Posted by CODYBOY View Post
I'm using the axial Kaiser 715 body.
[URL=http://s1264.photobucket.com/user/ledspots/media/TRX4/20-IMG_8263.jpg.html][/URL
Wheel base shortened to 12.5".
How did you shorten the to 12.5" and do the tires rub? I would like to get one of those bodies. Thanks.
singletracksean is offline   Reply With Quote
Old 06-20-2017, 11:06 AM   #26
Originally Posted by Natedog View Post
Love the Proline 1966 Ford F100 body! Looks good on there, but wheelbase looks good from here unless I"m missing something?
Edit: Got a straight on side shot and frontal view?
You most likely could run it at the stock wb with this body but I cut the fenders to work with a 13" wb which I prefer to run. The body I mocked up is from one of my other trucks. Next time I strip the trx down I'll get some pics
Old 06-20-2017, 11:26 AM   #27
CODYBOY's Avatar
To shorten the wheel base to 12.5" you will need to get at least 8 revo rod ends. Dlux Fab
Just replace the stock rod ends with these and it will shorten your wheel base to where you need it. (They are just a little shorter than the stock ones". If you wanted to go to 12.3 you would do the same on the front also. If you wanted to stretch the wheel base you would use the Jato rod ends.
I have my truck set up for 2/3 droop so when fully compressed they rub a little, but nothing that would hamper performance."thumbsup
Hope that helps you out.
Ernie
CODYBOY is offline   Reply With Quote
Old 06-20-2017, 01:24 PM   #28
The Axial XJ body is a great fit for the longer wheelbase TRX. In fact, I had to add Jato rod ends to the front of my 10.2 and extend the rear links a bit to correct the short wheelbase to fit the XJ body as many found out when they bought the 10.2 kit. For some reason the XJ body was designed for 12.5-12.8 inch wheelbase and they kept the 10.2 at 12.3
Axial confuses the hell out of me sometimes.
SCREAMER is offline   Reply With Quote
Old 06-20-2017, 01:46 PM   #29
I had been thinking that Revo ends might be the easy answer to shortening the wheelbase some but never actually measured to see how much shorter it would get. Good to know that you can get down to a 12.5 inch wheelbase with just a rod end swap.
svt923 is offline   Reply With Quote
Old 06-29-2017, 07:27 PM   #30
Im trying the proline toyota sr5 hilux body.. comes in two pieces leaving many options for a cage or full pickup build. Cant stand the stock body I refuse to even install it..
Zachariah is offline   Reply With Quote
Old 07-01-2017, 10:15 PM   #31
KMS
KMS's Avatar
Humbly here is the body for mine , 66 C10 , 2 piece kinda pain to mount and line , Its been a while since I painted Lexan ,Not my best do but the ROCK'S don't care ,,
Old 07-05-2017, 09:32 PM   #32
KMS
KMS's Avatar
I guess roll bar and bumper could fall under body thread ,, I used parts from a Honcho cage to make my roll bar for my 66 C 10 ,Front bumper ebay 9.00 ,LOL ,, gonna start on winch mount in a few days ,,,
Old 07-05-2017, 09:43 PM   #33
Originally Posted by Sabre8 View Post
Hello, do the inner fenders still fit well with this body like with the stock one?
Thanks
i do not have the inner fenders on this body. if i feel ambitious, when i paint a new blazer body, i might try and attach the fenders before paint... but we shall see... I will say, i usually run wheel wells (DIY tupperwear ones) and not having them on the blazer body reminded me why... The truck is a mess after every trail run. hahaha
eyeopenher is offline   Reply With Quote
Old 07-05-2017, 11:13 PM   #34
you could always attach the inners to the chassis instead of the body. was actually fairly straight forward
Old 07-06-2017, 09:48 AM   #35
yeah, after i read about the shoe glue to the body post mounts, i felt a little better about doing it...
Old 07-06-2017, 09:03 PM   #36
Shortened the wheelbase and running a Proline 4Runner.
kalani is offline   Reply With Quote
Old 07-06-2017, 09:23 PM   #37
How did and how much did you shorten the wheel base
kicker1 is offline   Reply With Quote
Old 07-06-2017, 10:01 PM   #38
How did and how much did you shorten the wheel base[/QUOTE]
Didn't touch the front suspension, only changed to similar length VP links and standard Traxxas rod ends. Shortened the rear links to 105mm VP links with standard rod ends (made top links longer for better pinion angle)
Moved the rear shock towers forward. Luckily it matched up with existing holes in the chassis
Had to remove the battery tray as it no longer fit and made one out of aluminum stock that fits a shorty pack perfectly and is lower than the stock battery position.
Old 07-06-2017, 11:02 PM   #39
battery tray no longer fit? curious, as i shrunk my rig a few mm's smaller than yours and had zero issues with the battery tray being there. (shock mounts on shortest factory option, and 102mm revo rods/rod ends)
Old 07-06-2017, 11:11 PM   #40
KMS
KMS's Avatar
Maybe that's what that extra piece in the parts bag is for ,,,,
what other bodies have you guys been running? - Similar Threads
Where's all the S.E. WI guys running at? Mopardude Wisconsin 12 11-20-2015 05:03 AM
How much caster are u guys running? wingnutcrawler General Scale Talk 3 03-27-2015 09:10 AM
RX/Tx? What are you guys running? molina Axial Yeti 18 03-07-2015 09:14 PM
Wraith bodies? What bodies are you running? AXLE 69 Axial Wraith 29 09-25-2014 01:17 PM
what shocks are you guys running? bro_die Axial SCX-10 21 06-17-2011 09:06 AM
