Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: what other bodies have you guys been running?
Old 07-06-2017, 11:19 PM   #41
Default Re: what other bodies have you guys been running?
ah-ha! good eye.. totally failed to notice he was still using the straight mount.
ubernewb is offline   Reply With Quote
Old 07-07-2017, 12:35 AM   #42
I like his battery tray more than stock though paint it black and good to go. Found out today my lhs has the 66 chevy body in stock gonna grab that for mine.
fr8cture is offline   Reply With Quote
Old 07-07-2017, 01:10 AM   #43
Originally Posted by ubernewb View Post
battery tray no longer fit? curious, as i shrunk my rig a few mm's smaller than yours and had zero issues with the battery tray being there. (shock mounts on shortest factory option, and 102mm revo rods/rod ends)
Sorry I meant I wanted to lower the CG of the battery and the regular stick wouldn't fit but I use shorty's on my drifter so
kalani is offline   Reply With Quote
Old 07-07-2017, 05:51 AM   #44
binaryterror's Avatar
I'll post up better tonight - this was first test after some needed changes to the wheelbase. But this is the Proline G6 Dodge Ram Single cab. I'll also include the details of what I did and actual wheelbase I ended at.
binaryterror is offline   Reply With Quote
Old 07-08-2017, 04:29 PM   #45
I got the body mounted then after laying a coat of paint on the bed I noticed this...
Old 07-09-2017, 03:08 AM   #46
Originally Posted by Natedog View Post
Looks like a hole? :/
Yeah its like it split right there from being too thin. A bummer only one my LHS had I'll have to wait on proline.
Old 07-09-2017, 10:52 AM   #47
KMS
KMS's Avatar
Thin spot ,,patch it with shoe goop on inside ,,
KMS is offline   Reply With Quote
Old 07-09-2017, 12:13 PM   #48
Tossedman's Avatar
Add some drywall tape to that goop. It'll make it stronger. Five bucks will get you enough to patch every truck body you'll ever own. FibaTape 150 ft. White Self-Adhesive Drywall Joint Tape FDW8247-U-FDW8247-U - The Home Depot
Tossedman is offline   Reply With Quote
Old 07-09-2017, 02:38 PM   #49
shoo goo 100% works a treat and then rock armour on the outside and colour code it
steven318is is offline   Reply With Quote
Old 07-09-2017, 08:44 PM   #50
KMS
KMS's Avatar
From all the other 66 C 10 bodies added to the TRX-4 I have mounted mine a little higher ,,not by choice ,, It had something about the rear body post mounting part that comes in the parts bad ,The stock mount didn't line up I have since seen a vid where it can be turned and lines of with the raised box on top of the bed for shock towers my guess, So what am getting at is the rock sliders mounted in the stock location were 1/2' lower than body and I wanted to use the grove in the slider to hold the body,, Here's what I came up with .
Old 07-10-2017, 09:08 AM   #51
Looks great with the sliders raised. When you said you had to mount it higher than the others I was thinking blahhhh. Then seen the pics and looks better than the others.
rag6 is offline   Reply With Quote
Old 07-14-2017, 07:30 PM   #52
Tossedman's Avatar
Here's mine with the body off of my SCX-10. Shortened the rear links and trimmed the frame rails a bit in the rear. Just first steps here, lots more to add.
Old 07-15-2017, 04:44 PM   #53
Tossedman's Avatar
Took the Bug out to the local Blackfoot RC Park here in Calgary. It's great with the TRX4 chassis under it. The shorter wheelbase allowed me to get around some of the tighter corners more easily and the lighter body meant it didn't roll nearly as easily as is did with the Defender body on it.
Old 07-15-2017, 07:47 PM   #54
What's the wheelbase on the bug body?
kicker1 is offline   Reply With Quote
Old 07-15-2017, 09:19 PM   #55
Tossedman's Avatar
I've got the chassis set to bang on 315 mm which is about 12 3/8". That's about perfect for this body.
Old 08-03-2017, 09:40 AM   #56
Just picked up a roller TRX4 and looking for body. Has anyone tried the Proline Dodge RAM 1500 body on? Another one I am considering is the proline hilux body.
Could you please share what links did you use to shorten the wheelbase?
metblack328i is offline   Reply With Quote
Old 08-03-2017, 12:12 PM   #57
Tossedman's Avatar
I used Axial links because I had them. 106mm for the upper rear and 98mm for the lower rear. I didn't change the front at all.
Old 08-03-2017, 07:16 PM   #58
Tossedman's Avatar
Oh, and I also shortened the rear drive shaft a bit.
Old 08-09-2017, 11:34 AM   #59
Has somebody tried the cherokee hard body with 313 WB?
Sabre8 is offline   Reply With Quote
Old 08-17-2017, 06:40 PM   #60
Has anyone tried the proline Jeep Rubicon body? Thinking of picking one up
Lenny718 is offline   Reply With Quote
what other bodies have you guys been running? - Similar Threads
Where's all the S.E. WI guys running at? Mopardude Wisconsin 12 11-20-2015 05:03 AM
How much caster are u guys running? wingnutcrawler General Scale Talk 3 03-27-2015 09:10 AM
RX/Tx? What are you guys running? molina Axial Yeti 18 03-07-2015 09:14 PM
Wraith bodies? What bodies are you running? AXLE 69 Axial Wraith 29 09-25-2014 01:17 PM
what shocks are you guys running? bro_die Axial SCX-10 21 06-17-2011 09:06 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
