08-28-2017, 10:01 PM | #121 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Codyboy Rebuilds His TRX4 "BULLDOG" |
09-01-2017, 02:05 PM | #122 |
Ok, magic yeti and carnaw, you weights are on their way. I sent you a PM with tracking numbers. Sacha, I didn't realize you have the brass portal covers until yesterday evening. They are a little thicker than the stock ones, so the weights hit them just before they snug up. So a couple things to fix that. I use a dremel and remove a couple mm of material from the inside of the weights mounting segment. You need to grind from screw hole to screw hole. Or you can remove the material from the pretty portal covers. Another thing you can do is put a little E6000 glue, or Shoe Goo in the holes on the portal and screw the weight on just so the screws are snug. The glue will keep the screws from backing out, yet will let you remove them without a problem. This will work for anyone else who wants to use my weights with the MFR portal covers. Ernie |
09-01-2017, 02:36 PM | #123 |
RCC Addict Join Date: Jun 2016 Location: Germany
thx ernie , i hope it's not a rowing boat |
09-07-2017, 06:55 PM | #124 |
Pebble Pounder Join Date: Dec 2007 Location: Cumming
How do I get some of these?
09-07-2017, 10:10 PM | #125 |
09-11-2017, 10:49 AM | #126 |
Ernie thx the Rowling boat arrived great craftmanchip. Front weights fits also on yeah racing Bras Portal Covers, Just a little sanding on one side was nessesary, only few 1/10mm Gesendet von meinem Nexus 5 mit Tapatalk |
09-11-2017, 01:55 PM | #127 |
Thanks Sascha, Glad you finally got them, and they look good on your truck. Where did you have to clearance, this is the first Yeah racing portal covers they have bin used with? Have fun with them! Here is a PM I got today that I wanted to share with you TRX-4 guys. Originally Posted by El Matador Just would like you to know that I did a comp this weekend. my bone stock trx-4 on a very rocky course that 2.2 were having problems I won the class as well as the tug of war. I can honestly say that your wheel weights were so obvious of an advantage that guys were complaining about them. I ran against highly modified trx-4 and every other make. My bone stock servo was cooked at the end of round 2 (I have at least 15 packs (5800 lipo) through it. Not bad for stock. I had a score of 34 and 31 the winner of the 2.2 unlimited had a 29/33. It was amazing seeing my rig going through the rocks and seeing other trx-4. I never even adjusted the shocks yet! Thank you again for giving me this unfair advantage. I'd say another happy customer! Ernie Last edited by CODYBOY; 09-11-2017 at 01:59 PM. |
09-11-2017, 02:22 PM | #128 |
just a little bit on the inside at the screw hole and one had a little offset between the rings. hope that descripe it right. if i have them of next time i will make a pic. no problem at all my dremel solved it. Gesendet von meinem T1-A21L mit Tapatalk |
09-11-2017, 03:55 PM | #129 |
Rock Crawler Join Date: Mar 2011 Location: USA
Been gone a few days did your PKG arrive from me ,,, |
09-11-2017, 04:29 PM | #130 |
10-12-2017, 03:08 PM | #131 |
I just did a little treatment to the Codyboy Wheel Weights using a product called Brass Black, its an acid and I believe it just tarnishes the metal. I took some pictures as I did it, I took everything apart and hit it with some steel wool Degreased with denatured alcohol I used a cotton swab to dab the brass with the brass black. The liquid is clear but turns dark blue as it touches the brass. first coat the cardboard worked out good, the brass black liquid soaked in an helped to get the sharp edges where the liquid wanted to pull away (surface tension). I flipped it and applied it to the other side while letting the bottom soak on the wet spot. after putting it face down and flipping it the coverage was a lot better Then I rinsed with water, they say to wipe it down with a soft rag but doing so was wiping off the tarnish so i did one more coat and just rinsed. they recommend a sealer but I'm not going to bother with it. I forgot to snap a picture of it dry, but the color ended up a bit on the gray side. EDIT: heres a few shots I'm pretty pleased with the results. Last edited by HumboldtEF; 10-12-2017 at 10:54 PM. |
10-12-2017, 08:48 PM | #132 |
They look nice Casey, that should make them blend in really nice. Are you going to take your Trx-4 and ascender to the RPP Jamboree. I 'm going to try and call Jim Logg at RPP tomorrow and find out if the fires are going to cause changes in the event? Ernie |
10-12-2017, 10:53 PM | #133 | |
| Re: Codyboy Rebuilds His TRX4 "BULLDOG" Quote:
I was wondering how the fires might play out too, I really hope its still on. | |
10-12-2017, 11:25 PM | #134 |
Newbie Join Date: Oct 2017 Location: Us
This has been an awesome build thread to read and look at. Your a talented person, some great work!
10-13-2017, 11:59 AM | #135 | |
Ernie | |
10-16-2017, 04:54 PM | #136 |
10-16-2017, 10:22 PM | #137 | |
If you pm me with your cell # Marcia will send you directions. Ernie | |
10-17-2017, 02:57 PM | #138 | |
Let me just get this out of the way though, Whats the main point of the titanium links? Mainly strength? or is it weight too? Pardon my ignorance. | |
10-17-2017, 08:50 PM | #139 | |
Ernie | |
10-18-2017, 05:44 AM | #140 | |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Benefits of Titanium over steel links is the sliding over rocks, the strength, and titanium is a memory metal which means even if you get it in a bad bind to bend slightly it's going to return to shape, not remain bent. | |
Codyboy Rebuilds His TRX4 "BULLDOG" - Similar Threads | ||||
Codyboy's "bulldog bronco" ascender | CODYBOY | Vaterra Ascender | 280 | 06-04-2018 10:09 AM |
Codyboy Designs "Northwest Express" Bud | CODYBOY | 1.9 Scale Rigs | 60 | 01-01-2018 03:04 PM |
Codyboy Designs "How'd you do that"? | CODYBOY | Vaterra Ascender | 60 | 04-12-2017 08:53 PM |
Bulldog/Mattzilla "Mountain Buggy" | Bulldog | 2.2 Scale Rigs | 88 | 03-30-2016 07:59 AM |
