06-17-2017, 10:24 PM | #1 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
| Toyzuki V2 chassis
I just installed the toyzuki V2 chassis with Traxxas axles. Will have to work out the gearing. I think I need about 9:1 spur/pinion. Sent from my Pixel XL using Tapatalk |
06-17-2017, 10:51 PM | #2 |
| Re: Toyzuki V2 chassis
Wow, very cool! I'd like to see how this turns out. You could set it up in full droop because you'll have plenty of ground clearance from the portals and that will give you really low CG without getting stuck on everything.
06-18-2017, 07:41 PM | #3 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
My oh my thats awesome. I saw your pics on Facebook earlier and man I can tell you the butt hurtness is real! One hater even said in the comments "Well the MST portals have more clearance" ..sigh.. I love the idea, subscribed for more. |
06-18-2017, 09:57 PM | #4 |
RCC Addict Join Date: Sep 2014 Location: Alberta
Killer concept, well done! What are your plans for the lockable diffs?
06-19-2017, 04:54 AM | #5 |
| Re: Toyzuki V2 chassis |
06-19-2017, 06:35 AM | #6 |
Very cool, I'll be watching this for future reference. 9:1 on the pinion/spur will be crazy low with the 7.65ish ratio at the axles and 2.6 in the transmission & t-case (95:1 overall ). A pinion/spur ratio around 2.5:1 will put the overall ratio in the 50:1 range. |
06-19-2017, 06:55 AM | #7 | |
| Re: Toyzuki V2 chassis Quote:
The transfer case has no reduction, either. The rear axle is 1:1 from the output of the spur gear shaft. The front axle is 1.3:1 from the same shaft. Sent from my Pixel XL using Tapatalk | |
06-19-2017, 06:56 AM | #8 |
Very cool. I bet this thing will be a beast!
06-19-2017, 06:57 AM | #9 |
| Re: Toyzuki V2 chassis Ahh, I thought you were using the full V2 setup. That gearing makes more sense now.
06-19-2017, 02:57 PM | #10 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
When I saw this on fb I knew it would be someone from rcc lol. Nice work I figured it would be done pretty quick
01-06-2018, 06:49 PM | #11 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Any updates to this build. What did you come up with for running gear ratios? How did it crawl? Ernie |
06-15-2018, 09:54 PM | #12 |
bump
12-22-2019, 01:14 PM | #13 |
Nice setup Casey, I put some TRX/GRC axles under a Brazin ALT chassis I guess great minds think alike. ... |
