09-04-2017, 05:57 PM | #41 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
| Re: Weak spots on trx4
My TRX4 has been underwater a lot. Opened up the diffs after a couple of hours in water and everything looked fine. I slathered loads of grease in there first but I can't see it being an issue with periodic reapplication of grease and say new bearings every 3-6 months. I personally found some (but far from many) bearings tended to get gritty after this time. The easiest method by far was to pull the axles out of the truck and use a cordless screwdriver. Probably takes an hour for both housings. I have yet to do the gearbox though...no idea there. |
09-04-2017, 06:54 PM | #42 |
I'm surprised you didn't mention temperatures...
09-04-2017, 07:33 PM | #43 |
| Re: Weak spots on trx4 |
09-26-2017, 12:45 PM | #44 |
Rock Stacker Join Date: Sep 2017 Location: in a RV
| Re: Weak spots on trx4 Take a soldering iron and place it on the stud holding the spare tire on. This will melt the locktite and you can remove the wheel nut easier
10-08-2017, 01:42 AM | #45 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
New bearings every 6 months?? I've only replaced the bearings in my Wraith once in 3 years of ownership.
10-08-2017, 06:07 AM | #46 |
Quarry Creeper Join Date: Feb 2017 Location: frothy river
I have to take some slack out of both f/r cables for the locking diffs I think. Hope its not too hard When it operates now it will 90% of the time mechanically engage in the differential itself, but 50% of those times I hear a buzzing or repeating sound from the servo as if its throw hasn't been completed, and I'm hearing in both micro servos sometimes. It's the cable right? I can still drive it I just need to listen carefully and make sure the servo is happy before I start. Last edited by Mountainsofbeer; 10-08-2017 at 06:10 AM. |
10-08-2017, 10:43 AM | #47 | |
| Re: Weak spots on trx4 Quote:
If not it may be the cables, have a look at my post in this thread I found a way to adjust cable length, and went over what I think is the ideal servo throw in a video in post #50 | |
10-08-2017, 12:46 PM | #48 |
Quarry Creeper Join Date: Jul 2013 Location: PA
I had my first failure... the 2speed shift servo....
10-08-2017, 10:44 PM | #49 |
Get the Blue Bird 373MG servo from HobbyKing. I have three of them in my Summit and they work great. You have to tell the controller to rotate the servos in the opposite direction from stock, but that's not a big deal, you can do it via the controller programming menu.
10-21-2017, 04:10 AM | #50 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
Weak spots on trx4 - Similar Threads | ||||
TRX4 Mods | chipgibbs | Traxxas TRX-4 | 83 | 05-01-2019 08:44 PM |
First crawl with the TRX4 | blarouche | Traxxas TRX-4 | 2 | 06-03-2017 04:12 PM |
TRX4 with 1.55"'s?? | skybolt | Traxxas TRX-4 | 24 | 06-02-2017 05:09 AM |
Thoughts on TRX4? | trascall10 | Traxxas TRX-4 | 1 | 05-02-2017 04:12 AM |
Opinions on replacement parts to fix Weak spots | armory | Losi Mini-Rock Crawler | 9 | 07-27-2013 12:36 PM |
