07-02-2017, 11:36 AM | #1 |
Newbie Join Date: Aug 2007 Location: houston
| Shorting the wheelbase?
I am trying to shorten the wheelbase to 11.4" for the mighty fc keep body but it seems like a lot to shorten the rear links. If I shorten the front it will change all the geometry for steering ect.
07-02-2017, 10:54 PM | #2 |
| Re: Shorting the wheelbase?
I looks to me like you could possibly take the front shock tower/servo mount and move it back on the frame rail after you drill new holes for it. You might get 3/8" to 1/2" if it works. It will make accessing the motor a pain though. But maybe you can just shrink it a little up front and a little in the back and keep your geometry. If you have the means make a custom servo mount to put it where you want it. Last edited by HumboldtEF; 07-02-2017 at 10:58 PM. |
07-03-2017, 06:20 AM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I don't think you'll be getting this truck down to 11.4" without major work. Like lots of cutting and drilling.
07-03-2017, 05:00 PM | #4 |
Rock Stacker Join Date: May 2017 Location: mukilteo
revo pushrods in the rear, revo ends on the stock front arms, trimming both driveshafts, cutting off the back of the floorpans, flip sliders left to right and vice versa. if you want to keep the inner fenders, that requires a bit more work but it's very doable. mine is at 300mm for my cherokee body, and i didn't touch the front links/driveshaft at all |
11-12-2018, 12:15 PM | #5 | |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Re: Shorting the wheelbase? Quote:
11-12-2018, 09:52 PM | #6 |
Rock Stacker Join Date: Sep 2018 Location: Pierce
If you need links you could use one of Harley’s ways of making links https://m.youtube.com/watch?v=N-n_8qglh6w I am gonna give it a try. Just bought the stuff tonight at Home Depot. |
11-12-2018, 10:10 PM | #7 |
Rock Crawler Join Date: Apr 2014 Location: Portland
Or you can buy 4 sets of these and make any wheelbase you need. 20-100mm 17pcs Red Aluminum Alloy Upgrade Links For AXIAL SCX10 1/10 RC Crawler https://www.ebay.com/itm/20-100mm-17...72.m2749.l2649 Last edited by Zukiiholic; 11-12-2018 at 10:11 PM. Reason: Adding info |
11-13-2018, 06:51 AM | #8 |
I was thinking about making my own links. I don't see it being all that hard to do. Just didn't know if there were links that someone had found that work out right. Once you buy everything to make your own. You're pretty close to the cost of most of the ones you can buy. Just saves some time. I don't always get a bunch of tinker time. I will make some if that's my best option tho. Thanks for the advise
11-13-2018, 03:12 PM | #9 |
Newbie Join Date: Nov 2017 Location: Tonawanda
ya'll shortening them up and I extended mine to 13" on the dot lol. At the last event everyone was amazed at the climbs I was doing. Only a couple people made it up them. I raised my sliders 1/2 inch to make them even with the center skid so the breakover isn't bad at all. Flat bellying it soon anyways. Sorry for rambling, you could easily shorten up the rear links and driveshaft to get to your desired wheelbase though. Cut stock links to desired length and re-thread them. You can easily shorten the rear driveshaft as well and modify the battery tray |
Shorting the wheelbase? - Similar Threads | ||||
Motor shorting on bolt for rock slider mount. | DowntownScience | Electronics | 6 | 04-10-2014 08:30 AM |
Motor Shorting to frame | Yorkster | Axial SCX-10 | 7 | 12-30-2011 08:44 AM |
ESC Shorting out servo..HELP!! | chevycrawlerking | Losi Micro-Rock Crawler | 0 | 09-01-2011 01:55 PM |
scx10 to LR3 - Shorting links | pipo | Axial SCX-10 | 7 | 03-02-2011 08:09 PM |
need help crawler shorting? | spgrading | Electronics | 2 | 12-23-2009 12:37 PM |
