Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: Titan 12 vs 21
Old 06-30-2017, 03:15 PM   #1
Default Titan 12 vs 21
So I have a titan 12 I pulled off my stampede. Do you think it would make my trx4 a tad quicker? I can sacrifice a bit of pull as I live in the keys with not much terrain. The 12 should be plug n play right?
Sent from my SM-T810 using Tapatalk
buscg1 is offline   Reply With Quote
Old 06-30-2017, 05:06 PM   #2
Natedog's Avatar
Default Re: Titan 12 vs 21
It will fit, but you'll probably burn up the 12T, not enough torque.
Keep the 21T 550.
Old 06-30-2017, 06:08 PM   #3
Are you running 3s yet?
calcagno45 is offline   Reply With Quote
Old 06-30-2017, 09:44 PM   #4
Also is the stock ESC even capable of running a 12T brushed motor?
Edit: no
ESC specs from Traxxas:
Input Voltage: 6–7 Cells NiMH, 2–3S LiPo
Case Size: 1.23” W x 2.18” D x 1.04” H
Weight: 2.6oz (74g)
Motor Limit: 21-turns (550 size)
On Resistance Forward: 0.004 Ohms
On Resistance Reverse: 0.004 Ohms
Peak Current - Forward: 100A
Peak Current - Reverse: 100A
Braking Current: 60A
Continuous Current: 18A
BEC Voltage: 6.0 VDC
BEC Current: 1A
Power Wire: 14 Gauge / 5”
Input Harness Wire: 26 Gauge / 14.5”
Transistor Type: MOSFET
PWM Frequency: 1700Hz
Low Voltage Detection (LVD): 2-Stage indicators, switchable (on or off)
Thermal Protection: Thermal Shutdown
Profile selection:
Sport Mode: 100% FWD, 100% brakes, 100% REV
Race Mode: 100% FWD, 100% brakes, no REV
Training Mode:* 50% FWD, 100% brakes, 50% REV
Trail Mode: 100% FWD, 100% Brake, 100% REV, Trail-Tuned Brake on Neutral
Crawl Mode: 100% FWD, 100% Instant REV, 100% Brake on Neutral
Single-button setup: Yes, Traxxas EZ-SetŪ
* Patented
HumboldtEF is offline   Reply With Quote
Old 06-30-2017, 10:29 PM   #5
Sure faster than 21t, however your tans, bevels and bearings going to damage very soon.
Teng is offline   Reply With Quote
Old 07-01-2017, 05:24 AM   #6
^ All correct With brushed motors the lower the turn the faster it will spin but less torque. It will also draw more amps and create more heat which is why it make sense that the motor limit listed would be the minimum # of turns and not the maximum.
Part of that limit they list could also be because they rate the TRX to use 3s and in other Traxxas vehicles using 3s with the Titan 12T that they ALL come with.. they don't last very long. makes more sense to go brushless at that point.
When I see the TRX4 bouncing around and wagging left to right at speed, making it go faster isn't the first thing that comes to mind.
So many better options for a fast scale truck ie. Axial Yeti Score or Losi Baja Rey. Get your tools and and wallet ready though if you want them to be reliable at 30mph, at least the yeti lol. And if you like Traxxas there are so many different models of Slash, if you think you are going to be into fast vehicles just get the brushless version straight away.
If you want a fast scale looking vehicle that can go 30mph+ and still respectably crawl over obstacles and rocks then check out the Yeti Rock Racer or the Losi Rock Rey, with the right mods you can really do everything with those but it still won't be as good a crawler or come with the trick features that the TRX4 comes with stock.
I am mentioning those two brands only because its what I have experience with not because that's all that's out there just wanted to clarify. Also I find that beating a hard obstacle driving the TRX-4 slow is just as satisfying to me but maybe I'm getting old.
Good question for 1st post!
Also don't give up on finding some terrain! It could be as simple as a drainage ditch filled with riff raff (rocks) can make a cool spot to drive.
Mountainsofbeer is offline   Reply With Quote
Old 07-23-2017, 02:20 PM   #7
Yeah I wasn't looking to make it 30 mph. I think stock hi speed is like 7 mph, I was looking more for 10mph or a tad over. Not much more just a little. I haven't tried 3s yet, all my lipos are 2s. I guess that could be my next try. Thanks guys.
Old 07-23-2017, 05:24 PM   #8
A 2200 30C 3S Turnigy Blue lipo is about $16; grab a couple as the truck will do about 20km/h. It's fine for this truck.
12T will cook itself and the ESC.
Now the thing that I took from the 2nd post was ESC: 18A continuous and 100A peak.
Are these values correct? A HW 80 is 80A continuous and 400A peak. The Traxxas ESC is certainly an egg cooker and these awful specs potentially confirm why.
CoolRunning is offline   Reply With Quote
Old 07-24-2017, 03:30 AM   #9
The XL-5 HV ESC in the TRX-4 is terrible.
"Peak Current - Forward: 100A
Continuous Current: 18A"
Hardcoretam is offline   Reply With Quote
Old 07-24-2017, 07:08 AM   #10
Holy crap! Lucky we didn't get their less fancy non HV version with the 14A continuous draw...ha!
HW 1080 here I come! Wow, those spec's after from yesteryear...did Traxxas honestly thing that was fine????
You know, I drove my TRX4 around my living room (in low gear with unlocked diffs) at a babies crawling speed (so not crazy slow mind) on the flat with the ambient temp at about 15C and the ESC got to 37C inside 10 minutes. I kid you not. 37C on floor boards just cruising around doing nothing.
Imagine in 35C summer weather crawling rocks...yikes...
Old 07-24-2017, 03:20 PM   #11
Well maybe you have binding issues or similar.
crazee horse is offline   Reply With Quote
Old 07-24-2017, 04:19 PM   #12
It's spinning freely. Just an 18A ESC at work. I knew it was suspect when my Bomber runnin high gear did the same crawling as the Traxxas in low gear and the Traxxas got nice warm and the Bomber was cold to the touch.
Titan 12 vs 21 - Similar Threads
Titan anyone? AddictedtoRC1 Axial SCX-10 13 10-21-2012 06:24 PM
Titan albinorhino Paint and Body 4 05-27-2009 08:57 PM
Titan ctcballer26 2.2 Scale Rigs 66 12-24-2008 11:18 AM
BB-51 Titan RcBro 2.2 Scale Rigs 107 02-12-2008 03:47 PM
The Titan bigflex Tamiya Clod Buster 7 12-17-2005 09:29 PM
