08-07-2017, 11:42 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Chandler
| New 3 Piece Aluminum 1.9 Beadlocks
Installing some 3 Piece 1.9 Beadlocks on Proline Hyrax Tires Paid $52 Shipped for the Beadlock on eBay and they fit perfectly, zero clearance issues. Will post pics on the truck once I get my Brass Portal Covers installed.. |
08-08-2017, 02:27 PM | #2 |
Newbie Join Date: Aug 2017 Location: Earth
| Re: New 3 Piece Aluminum 1.9 Beadlocks
Thanks for all the info on those beadlocks. I already saw them on ebay and would like to buy the same ones. I just want to know how is the offset? from the pictures if anithing I think they will stick out a few MM's out. can you measure the offset? are the beadlocks the same wide as the stock plastic wheel? Also looking could the stock traxxas tires be mounted on the beadlocks? I guess if the prolines mounted the traxxas tires also fit? Sorry if I am asking to much, I just want to buy the beadlocks to use with the stock tires, and I know some tire wheel combinations don't work, but so far I think its only the RC4WD wheels were you need the proline rings to mount the traxxas tires. If you can confirm that the traxxas tires fit and that the offset is the same as stock of close to it I will order them. Thanks Are this them? 4Pcs 1.9" Alloy Beadlock Wheel Rims fr 1/10 RC Axial SCX10 D90 CC01 30mm Wide-US | eBay |
08-08-2017, 05:27 PM | #3 |
Got them mounted up and the clear the MFR Brass Portal Covers with plenty to spare.. Last edited by djmaincheese; 08-10-2017 at 03:40 PM. |
08-08-2017, 05:52 PM | #4 |
Lot of ??'s for $50 I just want to know how is the offset? from the pictures if anithing I think they will stick out a few MM's out. can you measure the offset? Hard to measure exactly but they are between 2.5 -3mm more offset than stock. They don't stick out significantly enough to really notice, I think they look amazing on the rig are the beadlocks the same wide as the stock plastic wheel? Also looking could the stock traxxas tires be mounted on the beadlocks? I guess if the prolines mounted the traxxas tires also fit? Yes, same with as the stock rims Sorry if I am asking to much, I just want to buy the beadlocks to use with the stock tires, and I know some tire wheel combinations don't work, but so far I think its only the RC4WD wheels were you need the proline rings to mount the traxxas tires. I just bought a second set of beadlocks and the stocks tires mount up to them just like the prolines If you can confirm that the traxxas tires fit and that the offset is the same as stock of close to it I will order them. Thanks Stock Tires Hard to see in the pictures but a rough measurement difference I got was 3mm Are this them? 4Pcs 1.9" Alloy Beadlock Wheel Rims fr 1/10 RC Axial SCX10 D90 CC01 30mm Wide-US | eBay[/QUOTE] Yup those are them, comes with the hubs and all the hardware |
08-08-2017, 07:57 PM | #5 |
Pebble Pounder Join Date: Nov 2016 Location: USA
Not to derail the thread but, what length are those shocks?
08-08-2017, 09:06 PM | #6 |
| Re: New 3 Piece Aluminum 1.9 Beadlocks |
08-08-2017, 11:32 PM | #7 |
Newbie Join Date: Nov 2014 Location: Spain
In Aliexpress there are sellers who sell them something cheaper than ebay. I have two sets (one in silver and one in red) and I'm very happy with the quality. https://www.aliexpress.com/item/AXSP...802137320.html |
08-09-2017, 07:23 AM | #8 |
08-09-2017, 03:45 PM | #9 | |
| Re: New 3 Piece Aluminum 1.9 Beadlocks Quote:
Thanks for all the help from your part, I place an order for a set. | |
08-09-2017, 08:32 PM | #10 |
More Brass!!! Installed my Beef Patties, needed a little modding to fit my hubs. Adds 61g to each wheel!! Last edited by djmaincheese; 08-10-2017 at 03:40 PM. |
New 3 Piece Aluminum 1.9 Beadlocks - Similar Threads | ||||
1 piece aluminum hood/frontend | Barndog Racing | Axial Wraith | 5 | 07-10-2013 07:22 AM |
rc4wd 3 piece beadlocks | scale4x4 | Tires and Wheels | 1 | 06-10-2012 07:13 PM |
Build up of Axial; Kit or piece by piece? | Patrinos | Newbie General | 5 | 04-29-2010 09:52 AM |
