08-11-2017, 08:50 PM | #1 |
| Fix for slop in the motor mount
So I just made a quick video on fixing the slop in the motor mount. I did this a while back but a recent video posted by someone having the same issue made me want to put this video together. Just a bit of electric tape to the rescue, just a layer between the mount plate and the top plate seem to do it up tight. https://youtu.be/3_ICBHaaM7o |
08-11-2017, 09:07 PM | #2 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
| Re: Fix for slop in the motor mount
Interesting..... May try that in mine. I have 3, all have a fair amount of slop. Sent from my Pixel XL using Tapatalk |
08-11-2017, 09:14 PM | #3 |
At first I though cramming the tape in there would mess up the gear mesh so I ended up taking out the tape until today when a video prompted me to check again, I dont think it will mess with the mesh much at all, just make it consistent.
08-13-2017, 07:33 AM | #4 |
Pebble Pounder Join Date: Jun 2017 Location: Deep Woods
| Re: Fix for slop in the motor mount Me thinks we need some alloy parts. Hopefully enough of these trucks have sold to get the aftermarket interested in ramping up production on SOMETHING
08-13-2017, 08:08 AM | #5 | |
Pebble Pounder Join Date: Oct 2016 Location: Philly Area
| Re: Fix for slop in the motor mount Quote:
But yeah, we need an AU upper and lower spur gear covers, as the screws to bolt down the cover strip out the lower cover very easily. | |
08-13-2017, 01:13 PM | #7 |
Someone has already, I'll link you to the video showing how that item is the same spec and wobbles the same amount This is the video that made me want to put this fix up |
08-15-2017, 01:54 PM | #8 |
Pebble Pounder Join Date: Apr 2007 Location: shadyside
Hmmm, interesting checking mine also, thanks for the tip an video. |
09-22-2017, 05:21 PM | #9 |
I have had no issue with the motor mount being loose.
09-25-2017, 06:50 AM | #10 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I checked mine, it is tighten when in the truck bolted down and I can't move it at all. I can move it when shown in the video with just the plate and cover. I checked both how it is (HR aluminum plate and old cover) as well as a new set I bought for another project that didn't work out which is all plastic. Both seems fine when completely tightened down with cover and all. Tolerances must be just perfect on the 2 I tested is all that says. |
Fix for slop in the motor mount - Similar Threads | ||||
Simple fix for slop in the trailing arms. | Rockpiledriver | Vaterra Twin Hammers | 6 | 07-02-2013 04:53 PM |
Fix your rear axle slop on the super cheap! | mdchris | Axial XR10 | 14 | 03-08-2012 10:42 AM |
Cheap plastic rod end slop fix. | BENDER | General Crawlers | 13 | 11-28-2010 01:58 PM |
how to fix drive train slop?- help | Cationmoted | Axial AX-10 Scorpion | 10 | 07-16-2009 08:03 PM |
