08-14-2017, 02:35 AM | #1 |
Rock Stacker Join Date: Aug 2005 Location: Spain
| Tires or sponge, degraded?
Although in this photo the tire is under pressure, after 20 km of Rc hiking, the tires and sponge set, seem extremely soft, even deforming without any effort. The comparison is with the spare tire and with the first pics. Do this also happen to someone else? - - Last edited by trucktrial; 08-14-2017 at 03:02 AM. |
08-14-2017, 03:16 AM | #2 |
Pebble Pounder Join Date: Jun 2017 Location: Deep Woods
| Re: Tires or sponge, degraded?
The foam in these tires is too soft for my taste. Get them wet a few times and you will basically have four "flats" lol. When I removed mine to put on some beadlocks the foam had begun to degrade after just a couple of weeks. Sent from my iPhone using Tapatalk |
08-14-2017, 08:25 AM | #3 |
Newbie Join Date: Aug 2017 Location: Fort Carson
What is a good foam to replace the stock with that work good with the stock tires? I plan on getting some deadlocks, so may as well change the foam at the same time. My stock tires however are holding up very good and I will use them until one fails.
08-14-2017, 11:04 AM | #4 |
Pebble Pounder Join Date: Jul 2012 Location: Northeast
Mudflap is right, the TRX-4 demo truck at my LHS saw a little bit of water one time (when they first received it) and now it is resting firmly on four completely flat tires. They pulled one tire apart and the stock foam is discolored, smelly, and disintegrating badly. In fact, the foam is so bad we couldn't tell what color it was originally. I think when it was new the foam was white; now it's yellow and brown and crumbly. While sitting on the ground it looks like all four tires have been slashed. |
08-14-2017, 11:57 AM | #5 |
Newbie Join Date: May 2017 Location: 3420 E. Georgia Pines Lane, Mead
Personally, I like the Proline Dual Stage Foam inserts. They have the closed cell foam(the hard light blue foam) on the inside, wrapped by the open cell foam (the soft white foam) on the outside. This gives you enough give so that your tires will deform to the obstacle you're climbing, but won't collapse nearly to the rim. They also won't roll and bend over in hard turns with a little speed causing your vehicle to roll over. Plus, even though we aren't going for high speeds usually, if your vehicle is capable of higher speeds the pizza cutter effect is minimized by the hard inner foam. The Proline dual stage foam really is your best all around choice. They make them for 1.9 and 2.2 tires. The 1.9 XL size tires part number is: 6174-00. Now that I've mentioned sizes, I don't know all the sizes they offer. Sent from my SM-G930VL using Tapatalk |
08-14-2017, 04:20 PM | #6 |
Proline and Crawler Innovations make great 2 stage foams which allow a bit of deformation without collapsing as mentioned above.
08-14-2017, 08:37 PM | #7 |
Thanks for the tips...looking at the proline foam I believe. How hard is it to remove the tires from the stock rims without damage to either? I had bad luck trying to do so with my Slash :/ |
08-14-2017, 08:45 PM | #8 |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
i am using ci dual stage with med in rear and harder in front
08-14-2017, 08:45 PM | #9 |
Bake them in the oven!!
08-14-2017, 08:59 PM | #10 |
| Re: Tires or sponge, degraded? |
08-14-2017, 09:44 PM | #11 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
08-14-2017, 09:55 PM | #12 |
Must've been the cheap-o stock wheels on the slash. Wish Traxxas would've made some beadlocks to throw on the TRX4...I would've paid the difference personally, as long as it wasn't ridiculous. Although I understand a lot of people would not have wanted to due to being deep into the hobby already and having other sets and/or just wanting to pick the ones they want.
08-23-2017, 10:06 AM | #13 |
Yes, they definitely seem very poor quality, it happens only after two weeks of running in this river of clean water and staying underwater 15 seconds - - In my Emaxx this did not happen until after almost two years !! It is not a matter of replacing them with new ones and better ones, but it must not happen so quickly. |
08-23-2017, 01:49 PM | #14 | ||
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| Re: Tires or sponge, degraded? Quote:
I'm liking the Pro Line blue single stage foams so far, they fill in the tire nicely and have a stout construction, and precision cut. Having used CI, it's nice to have alternative options. Quote:
08-23-2017, 02:01 PM | #15 |
Like this |
08-23-2017, 09:31 PM | #16 |
Rock Stacker Join Date: Aug 2013 Location: Salina
Why didn't you or anyone else who's running the truck in water just cover the vent holes so water cannot get inside the wheel to destroy the foam? Way easier to do and it doesn't take any real money or a lot of work. Just seems like everyone is thinking about a fix when they don't know how to block the flow inside to the foams. I've ran many stock foams and wheels and tires in deep water on vented wheels. But I always did the necessary changes to stop water from messing up my foams. Heck take a plumbers tape and cover the holes on the inner part of the wheels. Takes very little time or effort. And guess what then you don't have any reason to complain. And it saves the effort. But this is just my opinion on the matter.
11-25-2017, 09:45 AM | #17 |
Newbie Join Date: Nov 2017 Location: Tonawanda
not only does taping the air holes prevent water from ruining the foams it makes the tire perform better as they are just too soft from the factory out of the box even when the foams are good
11-26-2017, 11:39 AM | #18 | |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
I have new wheels coming tomorrow so i needed to try this. PROPS to rock hugger and Natedog, Thanks for the insight to this method 3 tires went perfect so I decided to capture the last on video so I had to hunt down the GoPro... here is a video I made of this technique. I would not recommend trying this in your daughters easy bake ovens though https://www.youtube.com/watch?v=shAgrNEFQ7s I should go throw this up in the Tires and Wheels section. Last edited by ScoJac; 11-26-2017 at 12:12 PM. | |
11-26-2017, 12:07 PM | #19 | |
. My tablet won’t let me put 1000 thumbs up smilies damnit!!! Let me just be the first to quote comment and like this post!! I would like to Thank ScoJac for putting mine and Nate’s method into a super awesome how to video . And a fresh cup of coffee to you sir! Great job keeping safety in mind as well as these things get really hot inside. A few notes for the next user: 1. Gloves are a requirement 2. Ventilation of the area from fumes is suggested 3. One would even suggest eye protection (vaping CA glue can burn, it may also fling or splash out when softened). We used a 40 watt bulb and set the wheel directly on the bulb, I think your method is better (60 watt, paint grate, tin foil backing plate). Neither Nate or myself have a GoPro or Utoob account, but I’m glad ScoJac does!!! Can we get a sticky in the tire section for the video? | |
11-26-2017, 03:00 PM | #20 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
As the trx4 tires are slightly bigger do we still use the 1.9 dual foams or cut 2.2s?
Tires or sponge, degraded? - Similar Threads | ||||
Jesus sponge | Kranberry | Chit Chat | 5 | 03-03-2009 04:12 PM |
The AX10 polluted and degraded the 2.2 class! | RCMFMaxxMan | Chit Chat | 182 | 04-28-2008 08:03 PM |
screwed up sponge bob | braceysdad | Chit Chat | 17 | 02-23-2006 06:53 AM |
Sponge Bong Hemp Pants... | radishkid | Chit Chat | 2 | 08-11-2005 08:08 PM |
