09-05-2017, 12:46 PM | #1 |
Pebble Pounder Join Date: Aug 2016 Location: Chattanooga
| What's wrong with my trx4. Check vid on instagram link pleasr help https://www.instagram.com/p/BYq3wThg2gQ/ Got it back 5 days ago from traxxas after esc fried last month. They only took 5 daus I didn't ship immediately. Anyhow in video plugging the battery in causes a żjolt? of power, the light near receiver is green, and nothing happens when hitting the power on button on esc. Nothing works and only thing that does happen is energy burst for half a second as soon as battery is plugged up. Sent from my SM-G930V using Tapatalk |
09-05-2017, 01:06 PM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: What's wrong with my trx4. Check vid on instagram link pleasr help
Did you try to bind TX/rx again. Did you calibrate ESC? This would be my first try. Gesendet von meinem Nexus 5 mit Tapatalk |
09-05-2017, 03:15 PM | #3 |
And make sure your battery is charged properly, and proper mode is set lipo/nimh Hang up and Drive |
09-05-2017, 03:42 PM | #4 |
Quarry Creeper Join Date: Oct 2012 Location: Oregon
if you plug it in and everything powers up, it sounds like the button on the esc id screwed up... or the esc is fried.
09-05-2017, 05:26 PM | #5 |
| Re: What's wrong with my trx4. Check vid on instagram link pleasr help |
09-05-2017, 06:45 PM | #6 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
Seriously, don't futz around with the stock ESC if it's causing problems. I'd rebind and if it's not arming or even starting up (not great news), get the HW WP 80 and be done. It's a better ESC period and very affordable. |
09-06-2017, 03:48 AM | #7 |
Thanks guys. No time to mess with it but I'm just going to throw the mamba x I have in there. Possibly the hh puller pro 2200 from one of my 10.2s as well. I can't can't that combo warmer than them outside temp no matter how hard I run and watching the temp on stock setup got old quick Sent from my SM-G930V using Tapatalk |
09-06-2017, 09:01 AM | #8 | |
| Re: What's wrong with my trx4. Check vid on instagram link pleasr help Quote:
Sent from my SM-G930V using Tapatalk | |
09-06-2017, 11:38 AM | #9 |
Newbie Join Date: Aug 2017 Location: SG
remove connections of all servos from your receiver, except the one to the ESC power it on again. does it work? if yes, then its one servo shorting out and causing the BEC to overload and hence switching off. then you slowly figure out which servo it is. if no, and problem persists, its the ESC. |
09-06-2017, 12:00 PM | #10 |
It's the ESC Irregardless, on a proper working TRX-4 esc you can plug and unplug a battery all day long and nothing happens. His esc sends power to the receiver and servos the moment he plugs the battery in. Something is bypassing the power switch or some other issue in the ESC. Unplugging servos is not going to change that.
What's wrong with my trx4. Check vid on instagram link pleasr help - Similar Threads | ||||
What steering link? What did I do wrong? | Flim Flam | Axial SCX-10 | 28 | 08-14-2016 07:52 PM |
tamiya owners check this vid out | krazikev | Videos! | 1 | 03-28-2015 09:44 AM |
CTG Instagram vids compilation vid | Crawler Ted | Non Crawler RC's | 1 | 01-27-2014 12:14 PM |
Check out this Vid | Mechanicalbob | Chit Chat | 10 | 10-12-2007 05:20 PM |
VTec Rules Check out the Vid! | canucksrc | Chit Chat | 32 | 01-04-2007 09:06 PM |
