09-12-2017, 01:48 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: Cumming
| Front differential failure? With video.
Looks like some kind of diff failure. https://youtu.be/kdK-vhHfAVU Any thoughts on what it could be? It drives fine in reverse with the diff locked or unlocked. But forward turning unlocked and the left wheel won't turn. Locked it does turn but skips or jumps. Again this is all only when the wheels are turned. |
09-12-2017, 01:56 PM | #2 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
| Re: Front differential failure? With video.
did you check the CVD on that side? That behavior is more indicative of a broken CVD drive pin or other related parts. Either way diff or CVD is an easy fix. |
09-12-2017, 06:48 PM | #3 |
Pebble Pounder Join Date: May 2006 Location: in a house in alaska
ALL RTR'S need grease... but yeah rockhugger has.it
09-13-2017, 05:46 AM | #4 |
So it was the CVD not having grease from the factory. Resulted in this.... Shame since I am gone on vaca and can't get a replacement from anyone. So I just pulled the shaft and locked the front diff so I can run it in 3 wheel drive. Sent from my iPhone using Tapatalk |
09-13-2017, 03:00 PM | #5 |
Quarry Creeper Join Date: Oct 2012 Location: Oregon
That's not a grease failure that's a metal failure, the metal fractured around the pin. Looks like in making them strong the parts may in fact be on the edge of being too brittle.
09-13-2017, 06:34 PM | #6 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| Re: Front differential failure? With video. It might that the endpoints weren't set, or there was no mechanical stop and they got oversteered. That's the quickest way to break any CV / Uni.
09-14-2017, 07:53 AM | #7 |
| Re: Front differential failure? With video. |
09-14-2017, 08:24 AM | #8 | |
| Re: Front differential failure? With video. Quote:
To me it's not a big deal, just check the proper mechanics, replace the inner shaft and move on. It could be an anomaly, it could be a problem. Let us know if it reoccurres. Last edited by rockhugger; 09-14-2017 at 08:27 AM. | |
09-14-2017, 08:45 AM | #9 |
3s, I wasn't hung up on anything. Just ripping it around. I'll check the physical end points. I think was just a fluke but I ordered some replacements. Sent from my iPad using Tapatalk |
09-14-2017, 02:49 PM | #10 | |
RCC Addict Join Date: Jun 2016 Location: Germany
difference between rtr and kit: a kit i put together and i know what's on, rtr i have to tear down and put it back together so rtr is more work | |
09-14-2017, 08:43 PM | #11 | |
Are part hipster? Has anyone else broken these thus far? Maybe I'll order a set. | |
09-14-2017, 11:07 PM | #12 |
I have seen them break the outer gear portion of the cv axle but not yet seen a broken cv shaft.
09-15-2017, 06:49 PM | #13 |
"just rippin around" I'm guessing that also included some jumping as well. I think we just found the root cause. I wouldn't do too much "just rippin around" with the front diff locked or you will be replacing the spider gears as well. You would probably be better off removing the front drive shaft.
Front differential failure? With video. - Similar Threads | ||||
Front differential gears available? | Phylodog | Vaterra Ascender | 3 | 01-29-2017 05:13 PM |
New to RC and just bought a used CC01 having front differential problems? | jjosephlee | Tamiya XC/CC01 | 8 | 12-19-2014 03:39 PM |
Locking front Differential | 4X4 Freak | Axial Yeti | 10 | 12-14-2014 07:10 PM |
Front Differential | MachtSchnell | Vaterra Twin Hammers | 26 | 04-06-2013 11:42 PM |
Differential in front axle? | Jay-Em | Axial Wraith | 6 | 09-27-2011 01:49 PM |
