09-27-2017, 06:47 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Chandler
| MFR Brass C Hubs
Metal Fab by Reed C-Hubs came in and finished installing them. Now it's got some weight up front Sent from my SM-G955U using Tapatalk |
09-28-2017, 05:45 AM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: MFR Brass C Hubs
I think MFR did a good job for those wanting weight, but you do lose clearance in a few spots, likely due to being brass. Also I was hoping for more angles and fillets on the edges of the C headed down to help not get caught up. While the weight is way high, it's just too much honestly for my needs. I'm not running a stock body though so I have removed the top heaviness. Thinking mine will end up for sale sooner than later. |
09-28-2017, 07:28 AM | #3 |
The TRX-4 is going old school. Back in the day we threw as much weight as possible in the wheels and people realized that wasn't the best idea. It was a Band-Aid for a poorly setup truck. Now the same thing is happening with the TRX-4, but instead of putting the weights in the wheels they are making everything brass. This is a bad idea for many reasons. And brass is soft so brass rubbing on steel screws and other brass parts means you'll probably have to replace those expensive parts sooner than you'd like unless you can deal with all of the play and slop that will be created. These are brass Band-Aids, boys. |
09-28-2017, 07:44 AM | #4 |
Quarry Creeper Join Date: Jul 2013 Location: PA
Its just a way to sell parts.. anyone who has used the trx4 as a crawler or a trail truck, furthermore as a basher will likely regret the addition of mass weight.... I can totally wrap my head around knuckle weights or even portal covers(one or the other), however bottom links is laughable. But it seems you can sell ANYTHING on the internet....
09-28-2017, 09:01 AM | #5 | |
| Re: MFR Brass C Hubs Quote:
09-28-2017, 09:11 AM | #6 |
Quarry Creeper Join Date: Aug 2014 Location: Orange County
Someone should make a brass axle housing... lol Sent from my SM-G920T using Tapatalk |
09-28-2017, 01:28 PM | #7 | |
You'll never see me put weights in wheels, it is the worse place for it. Just adds rotating mass and more stress on parts. Knuckle/Portal weight in the TRX-4 case is ideal but some weight, not a ton, we both agree there. I have the brass outer portal covers on the front and they really helped and cause no issues. I'd like maybe a bit more but currently I'm using some overly heavy stamped steel wheels that help - until I get ready for some light aluminum 1.9s. I also got rid of the stock body (really more the structure that is the weight and top heaviness issue the body stripped is normal in weight) anyhow. So my weight needs are much more normal. | |
