Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Traxxas TRX-4
Thread: K10 body, bobbed frame
Old 10-11-2017, 06:59 AM   #1
Default K10 body, bobbed frame
I just figured i'd share my build.
I really like this body. It's one of my favorites. I really like this trx-4. it's one of my favorites... lol
So i used the stock body posts from the TRX4 up front. i just made 2 new holes in the body.
In the rear i used the stock vaterra posts that would go down into the vaterra chassis. I drilled 2 horizontal holes through it and ran longer rear shock mount bolts through them and created a hinge setup.
In the rear (test fitting here) the chassis was a lot longer than on the ascender.
Sooooooooooo
That's the result. I think it turned out nice.
The only other things i've changed are:
MFR brass portal covers
MFR tie rod
MFR lower links
Savox 500oz servo
NO brainer BEC
Raceline beadlocks
Alien compound pitbull rocker XL's
This thing just works.
2k2wranglerx is offline   Reply With Quote
Old 10-11-2017, 07:33 AM   #2
into the ether...
smog's Avatar
Default Re: K10 body, bobbed frame
The Ascender K10 truggy body is a cool one, aaand Its nice to see it fit over the TRX4. �� Great combo dude!
smog is online now   Reply With Quote
Old 10-11-2017, 07:47 AM   #3
Thanks man. I really liked that body. If you change out the cab you can do it without bobbing the frame. But i like how that turned out anyway.
Old 10-11-2017, 07:54 AM   #4
That looks really good
92fox is offline   Reply With Quote
Old 10-11-2017, 01:53 PM   #5
into the ether...
smog's Avatar
Not sure what you mean here. What cab would you have to change it out for?
Old 10-11-2017, 02:31 PM   #6
you can run the yota or dodge cab that's longer with the K10 bed/cage and it looks correct without bobbing the frame.
Old 10-11-2017, 03:39 PM   #7
into the ether...
smog's Avatar
Okay, gotcha.
K10 body, bobbed frame - Similar Threads
Anyone try a ascender K10 body on a TRX-4? MODC Traxxas Crawlers 3 10-11-2017 07:47 AM
'72 K10 body vs '66 F100 Cultus Vaterra Ascender 13 03-23-2017 09:43 PM
TF2 LWB Frame Rails for Custom K10? LSXGMC RC4WD Trail Finder 2 2 02-11-2017 07:54 AM
Bronco and K10 Body Options? Fourflys Vaterra Ascender 2 01-11-2017 05:45 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
